09-23-2009, 06:46 PM
Gen II Prianista
Clear Aero Wheel Covers; MBenz Does It First
Check this out:
Introducing the Brabus High Voltage Car
FWIW, today I got a chance to check out two Smart cars "up close and personal" like. Was surprised to see that the wheels are mounted with only three studs/bolts.
Am I mistaken or did the Citroen 2CV "Deux Chevaux" (Two Horses) also have three wheel bolts/studs?
Maybe some aftermarket parts makers will pick up on this and make some
for the unwashed masses.
The line starts here...
09-23-2009, 07:01 PM
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
I wonder if the 3 bolt pattern is the same as the Dodge/Common 6 bolt pattern, only missing 3 holes?
09-23-2009, 07:48 PM
Looks like a much smaller bolt pattern than the trucks.
09-23-2009, 07:55 PM
I bet they're not on in the pics.
09-23-2009, 08:04 PM
Pokémoderator
Christ -
The Tata Nano also has 3 bolts. Here's a closeup of another Smart tire :
CarloSW2
The Following User Says Thank You to cfg83 For This Useful Post:
09-23-2009, 08:22 PM
Smart = 3x112
Dodge/Common = 6X139.7/6X114.3
2.3mm is a little far, I think.
1/10 of an inch would probably still allow the wheel to bolt on, but I don't see it being safe, because the lug nuts would be applying shear forces on the studs, rather than just pulling force.
Anyone w/ a Smart willing to try it?
09-24-2009, 12:12 AM
Why would you put truck wheels on a Smart?
09-24-2009, 12:16 AM
I wasn't really suggesting that you could/should put them on, I just made an observation that they might have been interchangeable. There are bolt-on adapters made for Smart cars that allow the use of Mercedes 5-lug wheels. Why? Who knows. They're still out there, though.
My best guess would be the ability to have access to more/different aftermarket wheel styles than are currently available for the Smart's 3x112 pattern.
11-06-2009, 09:50 PM
#9 (permalink)
Gen II Prianista
BMW may have done it first, But Toyota follows suit on the custom Gen III
Prius, "Aerius," at SEMA 2009:
"A unique body kit and 19-inch alloy wheels (covered with clear covers to
reduce drag) help maximize economy, too."
I can't tell exactly how it is attached; something to do with the blue ray-like
things I guess.
SEMA 2009: Toyota Prius Aerius Concept
11-06-2009, 11:53 PM
#10 (permalink)
Pokémoderator
Rokeby -
things I guess.
I was able to blow up the picture to 2400 pixels :
I say there are six plastic arms attached to a center cap. The clear plastic cover is attached to two screws in each spider arm.
CarloSW2
The Following 2 Users Say Thank You to cfg83 For This Useful Post:
