Old 10-12-2010, 11:24 PM   #1 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 18.97 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
Why are there two different I-6 motors listed
for the f-series trucks? I was looking at some info on the 1991 f-150 and it listed 150HP and 145 HP under engines.....anybody know why? Is one for towing? Maybe more torque?
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 10-12-2010, 11:41 PM   #2 (permalink)
what are you looking at
Old 10-13-2010, 12:13 AM   #3 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
If you're looking at the EPA's fuel economy database, e.g. at fueleconomy.gov, it's because two different variations on that engine were offered. Different torque bands or emissions specs are good guesses.
Old 10-13-2010, 01:40 AM   #4 (permalink)
Team Pontiac
KBB.....
how do you know which is which by looking at them? My brother thinks he has the 145 and I think I have the 150 but not sure. His revs WAAY quicker but doesn't have the torque mine does.
1991 F-250:
Old 10-13-2010, 09:59 AM   #5 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
Both are wrong as there were three different 4.9 I6 motors.
4.9 L I6 1987–91 165 hp (123 kW) 275 lb·ft (373 N·m) EFI
4.9 L I6 1992–93 145 hp (108 kW) 265 lb·ft (359 N·m)
4.9 L I6 1994–96 150 hp (110 kW) 260 lb·ft (350 N·m)
Being a 1991 you should have the 165hp unless the truck was one of the last off the line and they used the 92 motor.
Try https://www.fleet.ford.com/maintenan...ls/default.asp and see if it will give you the engine details.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 10-13-2010, 12:17 PM   #6 (permalink)
Team Pontiac
manufacture date is 3/91, so it seems I got the "big" one....that might explain the different behaviors of the two motors. Almost like a gas vs diesel. His is very snappy and quick and mine feels heavier but is not lacking in the torque dept. It can get moving in a hurry if I am willing to sacrifice some fuel.
1991 F-250:
Old 10-13-2010, 12:25 PM   #7 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
What about just the regular old california vs US version?
I know lots of things are made 49 state legal, and then they have some extra cats/emissions equipment for the ones sold in Cali.
Old 10-13-2010, 03:22 PM   #8 (permalink)
If it "feels" like that much difference, his probably has higher ratio axle(s).
Old 10-13-2010, 04:13 PM   #9 (permalink)
Team Pontiac
He is running a 2.65? and I am running a 3.55.
1991 F-250:
Old 10-13-2010, 04:39 PM   #10 (permalink)
Team Pontiac
I just noticed on the door are the remains of a large decal that had "construction" in it. Looks like they tried to sand it off? That would explain why the engine runs so good. I don't know why I never noticed it before. The ford FLEET lookup does not match the label in the truck. The FLEET lookup says it has a GVWR of 10,000 lbs and the door says 6600. The wheel bases are also different. Should I go by what Ford says or the sticker? I know this thing will pull anything and will carry a full cord of wood with no problem.
1991 F-250:
Hybrid home conversion with rear hub motors blueflame Hybrids 42 01-25-2011 03:51 AM
Trolling ebay for motors, opinions welcome. Automcdonough Fossil Fuel Free 2 10-05-2010 12:55 AM
94 honda civic to EV, AC Motors? sirus20x6 Fossil Fuel Free 17 12-04-2009 10:55 PM
Hubba hubba hubba....that is, hub motors :) Pengyou EcoModding Central 47 04-10-2009 09:28 PM
Wheel motors much more efficient Otto General Efficiency Discussion 4 04-01-2009 07:22 PM
