Old 08-14-2008, 04:52 PM   #11 (permalink)
Sandstone Princess - '99 Chevy Sububan LT
90 day: 21.04 mpg (US)
Joe - '02 Nissan sentra XE
90 day: 43.9 mpg (US)
Regal - '03 buick Regal LS
90 day: 33.85 mpg (US)
Toyota Sludge Zone
Toyota settles class-action suit on oil sludge buildup - Los Angeles Times
I will withold my personal opinion of the toyota "quality" but, do some research on the sludge problem and other toyota engine/vehicle issues. If you do own a toyota, I would run nothing but the higher end synthetics in it to help prevent this problem.
Old 08-14-2008, 05:04 PM   #12 (permalink)
lovemysan's Avatar
gutless wonder - '02 Saturn sl sohc
90 day: 40.17 mpg (US)
econoburban - '05 chevy surburban 2wd LT
90 day: 19.43 mpg (US)
Well I chose not to buy a toyota sienna after reading about denied warranty claims despite proof of maintenance. You expect that sort of treatment from the lower tier manufacturers.
It pings hard when fully warmed under hard accelleration. When it starts to come on strong around 4k. I suspect the knock sensors are corroded and causing the problem. It could also be weak fuel pressure, o2 sensors, poor egr flow, or carbon buildup. All likely contributers. Currently it runs very well so I'll leave it as is. It doesn't always do it.
2002 Saturn SL
sohc + 5spd = 50mpg
mod pics see link below
http://s75.photobucket.com/albums/i3...emysan/saturn/
Real men have wheel skirts.
Old 08-14-2008, 07:00 PM   #13 (permalink)
Also run some really good fuel injector cleaner through it when you have half a tank left. I stick berrymans in it every few months. New fuel filter too
Old 08-14-2008, 10:29 PM   #14 (permalink)
lovemysan's Avatar
Checked tonight and no pinging, ran great, has lots of power. It may have worked itself out.
I hit a bolt tonight on the freeway. I suspected a possible issue so I started cycling through the tire pressure monitor. Before I could get to it the TPMS alarm went off stating that pressure was 20lbs in the afflicted tire. I pulled off and it promptly finishing flattening. A neat system.
2002 Saturn SL
sohc + 5spd = 50mpg
Old 08-15-2008, 09:05 AM   #15 (permalink)
Does that mean you can get a set of the Michelin X radial 6 ply tires for her?
Old 09-02-2008, 08:44 PM   #16 (permalink)
lovemysan's Avatar
I got 2 new michelin LTX M/S for the front and slightly used 2 cooper discoveries for the rear. For $50 each I couldn't turn the coopers down.
2002 Saturn SL
sohc + 5spd = 50mpg
Side mirror drag & effect on fuel economy - quantified MetroMPG Aerodynamics 179 11-10-2022 03:25 PM
Side View Mirror Downsize cfg83 Aerodynamics 20 07-13-2011 12:22 AM
Project HX - The flip side Vince-HX EcoModding Central 81 01-06-2009 10:57 PM
Side skirts fastening tasdrouille Aerodynamics 9 08-01-2008 01:24 PM
Bicycle side view mirrors? cfg83 Aerodynamics 2 02-15-2008 11:54 AM
