EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Just saw this on my local Craigslist (https://ecomodder.com/forum/showthread.php/just-saw-my-local-craigslist-36197.html)
Ecky 02-26-2018 12:35 PM
https://potsdam.craigslist.org/mcy/d...471784479.html
https://images.craigslist.org/00Q0Q_...rV_600x450.jpg
https://images.craigslist.org/00U0U_...wY_600x450.jpg
Here's an interesting opportunity and your chance to own a Tri-magnum (reverse trike). This design was was built years ago using plans available from the Feb 1983 Edition of Mechanix Illustrated. This example was mostly completed but should be considered a project. It's on a rolling chassis but needs to be finished. It's a solid build and stands roughly 42 inches tall, and about 14 feet long. The Goldwing underneath was disassembled and is basically non-functional. The good news is this Trimagnum comes with a nice, complete, 1980 Goldwing 1100cc (with clean paperwork) that will slide right in place of the non-functional one. The 1980 Goldwing has had a single barrel carb adapted to it for reliability - however - the original 4 carb unit is included. Google "Trimagnum" to learn more and see what others have done with theirs. Youtube videos of these are not difficult to find. The performance of a Trimagnum is basically limited only by the donor bike used. How wild do you wanna get with this spaceship????
Probably not all that aerodynamic, but neat. Thoughts?
Frank Lee 02-26-2018 12:41 PM
I think he's an EMer or at least a lurker.
kach22i 02-26-2018 04:14 PM
I looked up that design earlier today, too bad that the body does not taper more because of those rear taillights and the back half of the front wheels coverings isn't blended into the body.
If it were my time and money I'd rather invest in a Lotus Esprit barn find project car and at least have a remote hope of recouping my money.
I wonder what it would take to bring this Elan back to life.
https://www.ebay.com/itm/1968-Lotus-...JY2gs9&vxp=mtr
If you have to ask, you cannot afford it?
I mean, if you are going to be playing with fiberglass, play big, right?
Ecky 02-26-2018 04:32 PM
Oh, I'm not intending to buy, just thought I'd share. I'd never seen anything like it.
ennored 02-26-2018 04:49 PM
I can't decide if I should give or take away points for his use of Vega tail lights.
ChopStix 02-26-2018 09:36 PM
I used to own one. Though mine was done a bit different. But the Honda Goldwing conversions (tri-magnum conversion kit) used to be very popular back in the 80's. Here's some info on them.
https://uncommonmotors.com/tri-magnu...ld-wing-power/
And a google search provides a ton of pictures
freebeard 02-26-2018 10:18 PM
Thoughts?
Thanks for asking. Compare to
Robt. Q. Riley X-3
Fiberfab Aztec
Blackjack Zero
The XR-3 is front or rear drive (or through-the-road hybrid). The Scarab was based on a motorcycle, but you could revert back seasonally. The Blackjack Zero has a flat four in front. :thumbup:
My money is on the Arcimoto FUV.
fusion210 02-27-2018 06:36 AM
2 Attachment(s)
I saw one the other week as well!
https://charlotte.craigslist.org/cto...503901964.html
Pretty funky, too kit like for me however.
elhigh 02-27-2018 08:39 AM
I'm going to go with the non-EM suggestion: slot in a 1987-up GW with the six cylinder engine. That gets you a reverse "gear."
kach22i 02-27-2018 08:58 AM
Originally Posted by ChopStix (Post 562315)
From that search here is one that almost slipped between the cracks.
The story so far...
http://www.pettypb.com/3-cycle/image...forwebpage.jpg
Above is a shot of a Turbo Phantom which was designed and built in the late 70's.
