Kadet E GT EV Conversion
3 Attachment(s)
Hy all
i just bought this "beast" 960 kg / 115hp / and an echonomical 20l/100km hope to become an nice ev :thumbup: planned components drive: motor warp 9" paul's 500A controller 10 GEL forklift batteries chargers DIY charger solar pannels small 2 kw generator (petrol) for extended range or fast charge Attachment 4525Attachment 4526Attachment 4527 |
Hey look its already a EV it has a battery charger hooked to it... :D
Kidding. Keep the info coming... Dave |
update
the car is at the boday shop for repairs in the meantime we have ordered the comtroller (thanks Paul) and the motor (thanks Netgain) we have started the gas peddal conversion (pictures will follow) gas pedal is based on clasic design with cable and an 5k variator for batteries we plan to use 10 calcium batteries (around 100 EURO) SLA 75 wich will give is around 100km authonomy found compatible chargers for 144v list atached (can be used as guide for our charger) different batteries and chargers brochure atached including cheap calclium batteries Hotfile.com: One click file hosting found digital scope and pannelmetters for replacing old metters on car those fit perfect replacing old ones atached also here / maybe are usefull for others Hotfile.com: One click file hosting secondary solar charger .... secondary gas generator .... to be checked for performance |
8 Attachment(s)
progress
DONE signal lamps are now leds original lamp was using 25w lamps led lamps use 7 12v leds 0.6W all (0.047A measured for the 7 leds) price 10USD / Lamp TODO building signaling circiut because old relay will not work due to low current UPDATE i have found and ordered 100x150 cm of fotovoltaic cells for roof 200 USD for all will see the test for performance from diagram each cell is 36v/7A rear lapmps conversion will follow shortly Attachment 4726Attachment 4727Attachment 4728Attachment 4729 Attachment 4730Attachment 4731Attachment 4732Attachment 4733 |
8 Attachment(s)
work started to rear lights
but unforunately stoped for 1 week i need more leds :( for now only rear light is working calculated cost 30 USD/lamp block tests rear light 100 mA (0.1A) original light bulb 21W rear signal light 100 mA (0.1A) original light bulb 21W rear brake/position 100mA+50mA (150ma) original light bulb 21W/5W Attachment 4739Attachment 4740Attachment 4741Attachment 4742 Attachment 4743Attachment 4744Attachment 4745Attachment 4746 |
3 Attachment(s)
new signal relay is ready
original diagram was published on tehniq i have modified it for our needs biggest current is 50mA x4 when all 4 lamps are lit so max current must be arroud 200 mA i took 1A to be shure so for command i used an BD237 Q1=Q2=BC171 Q3=Q4=Q5=BD237 and also i have atached my simplified diagram price for simplified diagram 3USD Attachment 4754Attachment 4755Attachment 4756 |
2 Attachment(s)
solar pannel has arrived
36v 7A on load (252W real/250W rated) so i will need an dc2dc conv for 144v dimendions 1000x1500x5 mm price 200USD will replace car roof and blend into the car update i will change the 36v 7A on load (252W real/250W rated) dimendions 1000x1500x5 mm with 36v 5A on load (180W real/180W rated) dimendions 900x1100x5 mm price 180USD because the big one cant fit on the top of the car and add an new one on the hood later Attachment 4768Attachment 4769 |
1 Attachment(s)
update
buyed 4 rims with new tires for the car 195x50x15" 12kg each new tire+rim searching for an new carbon hood to be lighter than existing one searching for new bumpers Attachment 4774 |
Wow, you don't stand in one place long do you?:thumbup: Keep 'em comin' jerpelea, you be Mr. Dynamo! :D Eric |
1 Attachment(s)
info update
car is at car repair and is coming along nice now being disasembled and cleaned for rust after some searches for electrical part we need 1.dc-dc converter 36-144v (500W) 2.ac-dc converter for 110/128v generator (5Kw) so we need to buy/build them i have found an drawing of what i want it to look (bumpers and dors ) Attachment 4776 |
