Old 03-19-2013, 04:03 PM   #11 (permalink)
Blue Angel's Avatar
Previous Car - '12 Chevrolet Cruze Eco MT
Team Chevy
90 day: 44.29 mpg (US)
535d XDrive - '16 BMW 535d M-Sport
Originally Posted by Old Tele man View Post
FWIW, the Cruze turbo is thermally cooled by a "thermo-siphoning" coolant system, or so GM claims...there is no actual mechanical coolant pump. It's been discussed over on the CruzeTalk forum.
Yes... I posted a U-tub video on Cruzetalk of the coolant boiling in the turbo after shutdown. After doing some researching, I found this thermosiphoning is pretty much common in all water cooled turbo installations.
Having said that, I bet that housing still gets pretty hot, even with coolant boiling through it. Even more so if shutting down immediately following a period of high load. I may consider fitting a small coolant pump in line with the turbo water line and putting it on a timer so it runs for a minute or so after engine shut off.
I'm using Mobil1 synthetic, so hopefully it's a little more "coke" resistant than ordinary oils... even other Dexos options.
2016 BMW 535d
4100lb XDrive Eco-Yacht
Old 07-24-2013, 10:02 AM   #12 (permalink)
Blue Angel's Avatar
Team Chevy
Quazar, sent you a PM for an update (if one is available).
2016 BMW 535d
