Kinda ScanGauge w/o OBD
Hi there!
Is there any kinda equipment like scangauge for cars without OBD? No electronics at all. The only one I know is the vacum meter. Thanks! |
...how far back year-wise are you talking about?
...if it's got electronic fuel injection of any sort (throttle body, manifold, etc.) then possibly the MPGuino is usable? ...if it's straight carbureted, you might have problems. |
It's an old diesel engine from 1992 a ford fiesta 1.8D, I think the vacuum is the best solution right?
Does the engine have a throttle? If not, a vacuum is pretty useless.
But you can plug a vacuum meter on the brake vacuum lines right?
Won't it give the right data? |
...you really want to measure how hard (or not) the engine is "working" not the barometric atmospheric pressure that tells you the altitude. |
But i fitted on a gasoline Seat Ibiza like i said and was working! It connects to the intake manifold! Right?
So can do nothing to scan anyway the engine? |
A gasoline engine was vacuum in the manifold, that's just the way it works. This vacuum can later be used for brakes, etc. In a diesel there is no vacuum, so the brake assist has to be generated by an external pump powered by the engine. A diesel would work just fine without the vacuum pump, in fact it would have that much less load on its accessory belt or camshaft.
If your diesel has a turbo, then you can monitor the intake air pressure. It's not much, but always something. |
