EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   Koenigsegg camless engine and compressed air hybrid (https://ecomodder.com/forum/showthread.php/koenigsegg-camless-engine-compressed-air-hybrid-25016.html)
tjts1 02-20-2013 05:55 PM
You can skip the first couple of minutes, the interesting bit is toward the end.
http://www.youtube.com/watch?v=Bch5B23_pu0
niky 02-20-2013 09:09 PM
Fascinating stuff!
HydroJim 02-20-2013 10:40 PM
I've been thinking about doing just this sort of thing! Too bad I didn't have all the money ):
Krayzie 02-20-2013 11:06 PM
super cool
sendler 02-21-2013 06:24 AM
Finally getting rid of the cam shaft. Amazing it took so long. One day. all but the cheapest engines will have computer actuated valves.
NeilBlanchard 02-21-2013 09:02 AM
My question is this: where does the air pressure come from? Would electric actuation be more or less efficient?
Frank Lee 02-21-2013 09:07 AM
From turning the engine into an air pump on deceleration. And I presume there's an ICE driven pump for air demands outside of decel...?
2000neon 02-21-2013 09:18 AM
You are probably right, I wonder if there's any tricks to starting it up if the cars has been sitting for a while. I suppose it would have to always keep some pressure built up for the next startup, until the compressor could build up more pressure. As a supercar I would imagine that it sits parked far more often than it's driven, I wonder if there are any tricks to it like relieving pressure before storage, and building up more before startup. Although they could avoid that if it used an electrically driven air compressor that could run for a second before firing the motor.
cRiPpLe_rOoStEr 02-21-2013 01:03 PM
I've once found pictures of a French 4-stroke gasser which used sleeve valves without a camshaft.
darcane 02-21-2013 01:28 PM
There's also Coates rotary valvetrain:
Coates International Ltd. - Home
No cams...
The Koenigsegg video is very cool and has a nice explanation on how it works. But, it's not exactly new... BMW had a functional protype (using electric solenoids IIRC) about a decade ago. Still hasn't made it to production yet.
