12-21-2019, 09:57 PM
Ontario man pulled 53' semi trailer with a Silverado
I feel like there are ways this could have been done correctly. That should include an air system, which they did, but wouldn't they use a bed-mounted fifth-wheel hitch? Would you have called the cops or taken a picture and gotten out of the way? https://www.caranddriver.com/news/a3...-long-trailer/
One does not simply pull a semi trailer with a pin:
12-22-2019, 12:23 AM
That looks way safer than the 5th wheel trailer my dad pulled with something like a 1960 Chevy truck.
My dad cut a semi-circle out of 2 boards so that when they were placed together, would capture the 5th wheel ball between them. Then he bolted the boards to the side rails. The emergency chain was a come along winch cable.
Went through a full tank of gas going about 100 miles roundtrip. Ran out about 4 miles from home.
12-22-2019, 12:24 AM
I am pretty sure that boards are not rated for that.
12-22-2019, 12:37 AM
Probably something similar in size to this, and it would be called a kingpin and not a ball hitch:
12-23-2019, 12:08 PM
Rat Racer
What if they were pressure treated?
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
12-23-2019, 12:42 PM
Oh well then. That's different!
