Old 12-30-2013, 01:50 PM   #11 (permalink)
g
Originally Posted by rmay635703 View Post
A lead battery wears out each time you use it, yours likely was missing plate material from being used not sitting.
Only way to know would be to desulphate it and see what happens, more than likely toast.
i noticed on days it wouldn't work right on acc i had a volts gauge.. it was showing 8 volts and wouldn't crank over.. i disconnected battery picked it up and shook it alot. put it back in.. 12 volts, fired right up.. could this be a sign of bad plates or what is going on?
