Old 06-26-2008, 10:56 PM   #1 (permalink)
I Need Help With My ScanGauge 2 Cutoff Setting
The default setting is 24 and they recommend leaving it there unless you know better, but also say that it usually works best when it is 4 above the throttle position when the car is off. My Mustang says 16 TPS before I start the engine, so I tried 20 first and I've danced it around and nothing seems to work correctly. Any time I go into stealth mode, ScanGauge says I'm burning .19 gallons per hour. That's the lowest it ever goes to. Doesn't someone know where my setting needs to be?
Old 06-26-2008, 11:02 PM   #2 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
I can't think of anyone here running a ScanGauge in a Mustang. Have you talked to the company?
Consider that fuel cutoff not registering properly will probably have a very small effect on trip/tank mpg. When I talked to the designer about it, he figured non-registering fuel cutoff would work out to an error of around 0.1%.
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 4 06-01-2015 04:58 PM
Scangauge 1 - Some help please! jdubbs_scort Instrumentation 6 06-17-2008 03:26 PM
DIY- Setting Valve Lash for Honda SOHC Motors TomO DIY / How-to 7 05-27-2008 10:21 PM
Question regarding Scangauge MPG readout & DIY device Gregte DIY / How-to 5 05-19-2008 04:58 PM
scangauge coolant temp accuracy? Daox Instrumentation 12 05-03-2008 01:09 PM
