If you have heard of these, they're the most durable lithium chemistry, and they're starting to become commercially available at a decent price. The benefit is that they work down to -40C just like lead acid, and have a cycle life of 20000 cycles.
So I took a bit of a gamble and ordered one of these off a seller on Aliexpress known for sketchy products (grade B, used, defective cells). Kind of like this, but 5S (12V nominal), and I requested that they fit a 200A BMS to it. I measured the weight at 15.6lbs, right at their advertised 7kg.
https://www.aliexpress.com/item/4000906602346.html
It looks exactly like that case, and the case is honestly quite nice. It's sturdy and smooth, seems like a quality plastic molding.
Inside, well, maybe not so much, but I wasn't expecting much given how inexpensive it was. The battery slid around a little bit inside the case. The lid was only glued on at 2 of the 4 edges, so it was conspicuously sticking up in one corner. The voltage meter at the top is completely inaccurate. The charger puts out 14V, but the BMS seems to cut off charging at 13.3V, which is kind of weird. The customer support was pretty useless, they told me to not worry about it sliding around inside...[facepalm].
Okay to the disassembly:
Lid removed, whole assembly taken out of the case
Those are doubled up 8AWG wires going to some meaty copper lugs, which should do the job just fine. The resistance in any car's existing wiring loom is probably higher. The rest of the pack is shrink wrapped together with the BMS, which is dumb but not a problem for an automotive starter battery application, where the battery is only working hard for a few seconds at a time.
Shrink wrap cut open
A bunch of pouch cells taped together with fiberglass reinforced tape, then two layers of shrink wrap. I didn't get a look at the terminals but they're probably soldered to the wires, and then some foam was packed around. Not the sturdiest construction, but...I guess it will do. We can see the heat sink for the BMS is separated from the pouches by a PCB, but there is no airflow going to it, so this is definitely not going to work as an EV battery under high duty cycle.
Crappy closeup of the BMS
It's marked "car starter BMS" on the PCB, and has a ridiculous number of MOSFETs. I guess that is pretty reassuring, I'm not going to question the 200A continuous rating.
Crude capacity test to come tomorrow. My only hall effect ammeter is a high current one, so the resolution is very poor (only within 1A ish), but I will try to attach it to a car and turn on the headlights and ignition for a ~30A load. Right now it's sitting a little above 13V, aka full. I'll measure the load current and check the voltage at 30 minutes to get an approximate capacity by referencing the standard voltage vs. SOC chart.
