Old 11-14-2008, 09:40 AM   #11 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
Okay, i'm not really sure if the limiting factor of these things is torque or power, so that may make or break the CVT argument.
I look at Ben's car videos and I see a car that has to either choose to be in the right gear to take off at a reasonable rate, OR go fast. A CVT gives you both.
I'd be willing to bet that just like a Diesel-hydraulic system has a "peak efficiency rpm" explaining their efficiency gains, you will find that any electric motor also has a peak efficiency RPM. Most likely it is a "medium pace" (ie, low-rpm causes high currents, high rpm requires higher voltage [i'm no expert, that's just want i see in the small motors i work with as a computer engineer])
Ben... here's an idea... take your car to a dyno shop! See if you can somehow also plot amperage against the torque&power vs rpm curve!
Old 11-14-2008, 01:03 PM   #12 (permalink)
hey Ben, checking the SF Craig's List lately has produced several leads for 5spd 3 cylinder Metros for $900-$1300 (no rust California cars). I'd lbe ooking at something like that, even if it meant a road trip.
It seems less expensive gas brough the prices down by 40% out here.
Story of a custom 5th gear for a '98 Ford Escort ZX2: +6% MPG MetroMPG EcoModding Central 14 03-05-2020 06:20 AM
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Saturn S-Series 5th Gear Swap cfg83 EcoModding Central 61 05-02-2012 09:31 PM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Met an unhappy Aveo owner today MetroMPG General Efficiency Discussion 24 10-10-2010 07:03 AM
