Loft bed with a normal ceiling
I just moved from my own apartment to a room in a duplex five blocks from where I have classes. I did not have enough time to go through my stuff and get rid of everything that I do not need, plus I have all of my Army stuff, so I searched on-line and it seemed like a loft bed was ideal.
I did not realize they are so tall! https://fbcdn-sphotos-d-a.akamaihd.n...77796077_n.jpg My ceiling is perhaps an inch higher than my 4'x8' campaign sign, on its end. Do you think that I would be okay cutting off a foot or two? I just want to make sure that I do it right! |
Heat rises, so it's gonna be HOT up there during summer heat, but conversely it'll be nice & cozy during the COLD winter nights.
Just remember, measure 2x (or3-5x) and cut once.
Old Tele man, I did not even wear a jacket this past winter, but I need to keep fans running to avoid sweating. I think that I am going to start wearing my noise-canceling headphones to prevent headaches.
I figured that I would need to mount fans up there. |
6 Attachment(s)
Cutting off the legs was the easy part! I actually did look at the "instructions," but there were not any, and I am not sure how much it would have helped, since it was already partially assembled, which may have made it more difficult. At first I assembled the outer frame, which would have been fine, had the bunk not been completely assembled. Everything fit together with bolts and glue-in dowels, so I would attach some part, then need to loosen the bolts, pry the sections apart, and then make the new one fit. There was some irony in purchasing a furniture because I needed space, yet hardly had the space necessary to put it together. Another person would have been a great help, too.
I have not been up there yet, though. Now that I have room to work, I am going to organize my stuff. I did not throw away and recycle enough, but there are many things that I plan on donating. It is just nice to be able to walk around my room! I am also posting other projects that I had: The kitchen floor, which still needs more work, the shower that I share, which is not finished either, and the refrigerator. I would have renewed my World of Warcraft subscription over that, had I the time. It took hours! I was scrubbing the door when I learned that black mold was trapped under the seal, which I needed to remove, and that was a nightmare. http://ecomodder.com/forum/attachmen...0&d=1369036995 |
Now you made me also consider to get a loft-bed...
Hey guys, just a quick update! I have successfully used the loft bed for six months without it collapsing and killing me, which I consider to be a success! :) I bought some metal shelves on a Lightning Sale through Amazon and used it and some spare lumber to mount a box fan to blow at my feet, but the bed has always creaked, although not enough to cause... alarm... just concern.
I keep thinking of different ways of bracing it, but I always decided that not failing school was more important. One guy bought the same bed, drilled holes in the posts, and ran cables. I do not know how much that would cost, but I do not like the idea of trying to strengthen the bed by putting holes in it. I would make wooden crossbraces if I did not think that it would take too much time. I ended up just looping the ends of a cargo strap across opposite corners and tightening! I have only done one end so far, but it is rock solid! This is the cable solution: IKEA Hackers| Clever ideas and hacks for your IKEA |
Did you acquire more crap to fill out the rest of your room yet? ;)
wow. looks nice. good job
