Old 01-26-2023, 04:18 PM   #1 (permalink)
'propeller' cars
Another look backwards:
https://en.cockpitdz.com/post/propeller-cars
freebeard (01-26-2023), Joggernot (01-30-2023)
Old 01-26-2023, 06:59 PM   #2 (permalink)
The Schlörwagen segment shows a Template overlay.
Old 01-27-2023, 12:11 AM   #3 (permalink)
IIRC in some places a safety cage around the propellers of outboard motors is required in order to decrease risks for marine wildlife, so a similar approach could be tried if a propeller-driven car was really worth the endeavour.
Old 01-27-2023, 12:39 AM   #4 (permalink)
90 day: 29.78 mpg (US)
Why scrape about the surface when you can untether from earthy bounds?
Old 01-27-2023, 12:00 PM   #5 (permalink)
Gettin' groceries.
Trains came with jet engines.
Turbojet train
A turbojet train is a train powered by turbojet engines. Like a jet aircraft, but unlike a gas turbine locomotive, the train is propelled by the jet thrust of the engines, rather than by its wheels. Only a handful of jet-powered trains have been built, for experimental research in high-speed rail. Wikipedia
Old 02-01-2023, 01:15 AM   #6 (permalink)
Even though FOD could ruin a jet engine, the engine in a jet train was supposed to be at a position which would render some accidents more unlikely. Years ago, a former teacher of mine mentioned an accident which happened with a Varig engineer, whose hands and part of the forearms were chopped by the core of an aircraft engine which I don't remember if it was a pure-jet or a turboprop.
Old 02-01-2023, 04:27 PM   #7 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
https://www.hagerty.com/media/opinio...propeller-car/
In which an entertaining automotive writer and an entertaining operator of a museum for oddball cars go for a little spin.
The Following User Says Thank You to wdb For This Useful Post:
Joggernot (02-02-2023)
Old 02-01-2023, 05:13 PM   #8 (permalink)
Are you buying it?
Your 1932 HELICRON propeller car is a miracle of modern engineering with an engine too powerful for its own good!
[snip]
Rear-wheel steering requires caution. Please do not turn so quickly that the car lifts a front wheel, topples onto its side, or drifts the propelling blades into the path of oncoming vehicular traffic.
This behavior is entirely normal and in many counties legislated as ordinary and no one should be alarmed at all.
Old 02-01-2023, 06:36 PM   #9 (permalink)
Jet engine motorcycles
Prop cars make interacting with pedestrians more interesting.
Old 02-01-2023, 10:10 PM   #10 (permalink)
https://jetoptera.com/technology/
Jetoptera use a fluidic propulsion system that's more efficient than a pure turbojet. No exposed blades or hot exhaust.
https://assets.newatlas.com/dims4/de...rrangement.png
