Old 05-01-2015, 12:06 AM   #11 (permalink)
There is a speed which aerohead will know below which there is no organized airflow around the vehicle. Was someone over-thinking things a bit on 4/20? The velocity squared thing really works in you favor. Structure and packaging are still there though; so, for instance in Electrathon racers, they tend to be prismatic.
https://www.google.com/search?q=carb...bicycle+spokes
aerohead (05-01-2015)
Old 05-02-2015, 05:36 PM   #12 (permalink)
A typical bicycle wheel uses 14 gauge 2mm steel wire for spokes. On a 36 spoke 3 cross build for a 26" rim the front spoke length is 10 to 10.5 in. based on the hub flange. A round spoke and a box section aluminum rim seem to give the best durability for the weight. Short of spending hundreds of dollars on racing wheels, lightweight wheel covers are the most common aero wheel treatment.
The Following User Says Thank You to Grant-53 For This Useful Post:
aerohead (05-02-2015)
