Old 02-28-2010, 02:58 AM   #1 (permalink)
B.O. Zen
Pickup - '99 Toyota Tacoma 2wd, Regular Cab, Short Bed
90 day: 34.62 mpg (US)
Wind power extracted from turbulent air
Random late night idea: Would it make any sense to use turbines to extract power from air just before it goes turbulent at the back of a vehicle?
How about running a fan (or an array of fans) gyro-copter-style just behind the detachment point to force air into the low pressure area behind the car? Could something like this be used in such a way as to smooth out the flow behind the car enough to justify the energy spent spinning up the blades?
Old 02-28-2010, 05:43 AM   #2 (permalink)
Cd
Ultimate Fail
Cd's Avatar
My 1 cent :
[QUOTE=a8ksh4;163383]Random late night idea: Would it make any sense to use turbines to extract power from air just before it goes turbulent at the back of a vehicle?
Several years ago ( around 1999 ), Popular Mechanics had a tiny snippet of information on a company that had modified a van with a fan mounted on the roof. The fan was mounted on its' side and the blades would twist in such a way that they would become flat as they reached a certain point, reducing drag.
As the vehicle would drive forward, the blades would turn in the wind charging the battery ( this was an EV concept. )
Like so much that PM prints, it was apparently all empty promises.
Not sure if that was any use at all, since that doesn't answer your question.
Check out my thread on Coanda slots. There has been some research done on using high pressure air to blast the wake into a more ideal shape.
http://ecomodder.com/forum/showthrea...ots-10972.html
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Diesel Power Magazine Disappointment. ConnClark EcoModding Central 16 06-05-2009 10:39 PM
OEM Air Injection, Yay or nay? Dane-ger EcoModding Central 11 01-14-2008 10:05 AM
