Old 04-25-2014, 04:12 PM   #1 (permalink)
Oceanic815's Avatar
02 Escape - '02 Ford Escape
90 day: 17.99 mpg (US)
87 Comanche - '87 Jeep MJ
90 day: 24.21 mpg (US)
LT Load Range 'E' Tires
Hello all,
My daily driver Jeep pickup is in need of a replacement set of summer tires; presently I am running oversized P245/70/16 Toyo Open Country with a max pressure of 35. I am considering moving to a LT Load Range 'E' tire as they can be aired up to about 90 psi in an attempt to reduce rolling resistance, increase fuel economy, etc.
I realize that tires aired that high will be super stiff and affect driveabilty and handling, but my truck is rarely driven over 55 as a commuter a few days a week... maybe once or twice a summer it will actually haul heavy or large items [winter has a fiberglass topper +3 60# sandbags].
Any thoughts on the E tires? I am still a little new at the entire fuel economy game but am eager to learn.
Thanks!
15 Toyota Prius Three with solar roof - rear diffuser
08 Ferd Escape 2wd 4cyl - stock
85 Volvo 245 lowered with IPD springs and Bilsteins
Old 04-26-2014, 07:44 AM   #2 (permalink)
Joggernot's Avatar
Remember that 6-ply light truck tires are 80 psi max sidewall. That might be what you are looking for. 4-ply are backed down closer to 50 psi max sidewall. I run 50 psi in the Toyota Tundra with no problems.
Old 04-26-2014, 07:56 AM   #3 (permalink)
Tire Geek
CapriRacer's Avatar
I'm not sure what you are trying to say here, but I think it is incorrect.
The typical construction for a tire is 2 sidewall plies - typically polyester - and 2 steel belts in the tread area. This applies to passenger car tires, and LT tires, regardless of the Load Range (Ply Rating).
EXCEPTIONS:
Small passenger car tires don't need 2 plies, so you will frequently find those with a single body ply.
High speed rated tires generally have cap plies (nylon) over top of the steel belts - sometimes 1 ply, sometimes 2
Sometimes even lower speed rated tires will have cap plies - as cap plies really reinforce the tire and delay tread separations from appearing.
Sometimes LT tires will have cap plies - also for reinforcement and delay of tread separations.
I hope that clears things up.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
Old 04-26-2014, 10:14 PM   #4 (permalink)
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
I have LT E rated truck tires on my XJ Cherokee. There doesn't seem to be much rolling resistance change above 40PSI. They are also much heavier than a P-rated car tire.
What I noticed playing with pressures: Anything above 40 and wheel bearing life can be measured in months.
60PSI and above: The jeep will actually bounce off of the road when you hit bumps. Good shocks or not.
I do like having E rated truck tires for going off road. Less likely to put something through the side wall. And they seem to wear like iron.
Old 04-27-2014, 09:56 AM   #5 (permalink)
Diesel FTW
PAFirefighter11's Avatar
Golf TDI - '03 Volskwagen Golf TDI GL
90 day: 44.63 mpg (US)
I run 32x10.10x16" Mickey Thompson MTZ mud tires, E range. I run them at 44psi on road and 15 off-road. 'll be honest, I'm not looking to improve FE on the Jeep. It's a lifted, 5.9L ... JEEP lol. They rock though. Great off-road and good on-road.
-Rick R
-'03 Volkswagen Golf TDI (49.9 MPG - Stock with Eco Friendly Tires
-'98 Jeep Grand Cherokee 5.9L - 32" MTZ's, 4.5" lift (11.5 MPG)
-'98 Pontiac Firebird Trans Am WS7 5.7L (22 MPG)
-'01 Pontiac Firebird Trans Am WS6 5.7L (22 MPG)
Old 04-27-2014, 02:35 PM   #6 (permalink)
Load range E tires are heavy and expensive. I wouldnt bother.
Old 04-28-2014, 11:54 AM   #7 (permalink)
Oceanic815's Avatar
Great, thanks for the feedback. I don't think bouncing off the road sounds like too much fun and will keep it at less than 50.
