Old 05-28-2008, 08:50 PM   #11 (permalink)
penny pincher
kevlar's Avatar
lucky - '92 Toyota pickup plain
90 day: 32.08 mpg (US)
Johnny M, how do you manage almost 54 MPG on the metro? nice accomplishment!
Would that be possible on a tercel? I don't seem to see a lot of high MPG tercels here. Might sweet talk the kid into selling me his.
Every dollar I save, .....I save!
half exposed Lucky http://ecomodder.com/forum/attachmen...1&d=1210727433
how it was done...
http://ecomodder.com/forum/showthrea...html#post25264
as of feb. 09, still holding up great with new owner,
who has since re-geared the rear end and gets nearly 40 MPG!
Old 05-28-2008, 09:09 PM   #12 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
First off, the car got about 45 MPG stock since it's a 1.0L 5 speed. Here are the steps I used to achieve well over 50MPG..............
Weight reduction (removed any and all un-needed weight)
Driving habits (I use a lot of those posted here on Ecomodder)
Slight aeromods (Radio antenna, rh mirror, partial grill-block)
Engine tweaks (Timing, air intake, etc)
Tire pressures (all set to 44 PSI)
Transmission (older Higher Ratio trans from a 92 installed by previous owner)
I would have to say most of my savings come from driving habits (I do not turn engine off "EOC" though) and the weight reduction comes in second and tire pressures third. I have not been able to warm the wife up enough to go extreme on the Aeromods like fender skirts, larger grill block, smooth wheel covers, etc. I am on the hunt for a "Project Metro" that I can put in my garage and tear it down to nothing and make it new again. After it's done, the current Metro will get redone also.
If my calculations are right, Aeromods like I mentioned above would get me over 60MPG easily.
GeoMetroforum.com - got mpg?
Aeromoding my truck ('95 Chevy S10 pickup) bennelson Aerodynamics 42 12-17-2010 06:28 PM
Toyota concept aero truck LUVMY02CREW The Lounge 14 11-14-2008 12:16 PM
I took out a guy on a bicycle with my truck.. Chris D. The Lounge 16 11-01-2008 10:00 PM
Review: 2009 Toyota Corolla LE (37.9 MPG) RH77 General Efficiency Discussion 22 05-09-2008 04:55 PM
[CRXMPG FAQ] SuperMID and 1990 Toyota Truck SVOboy Instrumentation 0 12-04-2007 03:51 PM
