Old 05-23-2014, 10:11 AM   #1 (permalink)
10MPG w/ 8.5'x16' Trailer
What determines an engine's stall speed?
Folks, since there's more technical discussion on this forum than any other I've found, I'll pose this question here.
WHAT DETERMINES AN ENGINE'S STALL SPEED??
I have a good feeling that this discussion could, and will be, closely related to one involving engine lugging; where and why it happens. I'm defining stall speed as the engine speed at which the engine, under no load and no throttle, will no longer run, shutting itself off.
A few observations: different engines appear to have different stall speeds, and I'm not sure what determines that. Most automobile engines, regardless of size, seem to have a stall speed of around 400 to 450 RPM. Other applications have much different stall speeds. The old hit-and-miss engines, like you'll see at the state fair sometimes, actually operate around 200 RPM, IIRC. Large marine diesels (like those that power ships) operate at very slow speeds as well, on the order of 150-200 RPM.
So, I have a theory about what determines the speed at which an engine can run, and it's simple: cam design. I'm not completely convinced, though, and would love if someone would attempt to verify, or counter my idea, with good technical backing.
A little background on my theory, to get you thinking on the same lines as I am. Consider a single-cylinder engine, running normally. A normal camshaft's events are timed relative to crankshaft position, in degrees of rotation. For instance, it might have the following specs:
-Intake valve(s) open @ 4 degrees Before Top Dead Center (*BTDC),
-Intake valve(s) close @ 20 degrees After Bottom Dead Center (*ABDC)
-Exhaust valve(s) open @ Bottom Dead Center (BDC)
-Exhuast valve(s) close @ 15 degrees After Top Dead Center (*ATDC)
organized in order of crankshaft rotation, these go:
so, notice a few things off the bat:
-at the top of the piston stroke, both the intake and exhaust valves are open at the same time, for a short period of time, from 4* BTDC to 15*ATDC. This is "valve overlap."
-at the bottom of the piston stroke, the piston starts moving back UP 20* of crank rotation BEFORE the intake valve closes.
Both of these situations seem counter-intuitive:
-"Why would you open both intake and exhaust valves at the same time? Wouldn't that blow fresh intake charge out the exhaust port, or exhaust gas into the intake?"
-"Why would you close the intake valve AFTER the piston reaches BTC? Wouldn't that push air back OUT the intake, since the piston is moving back up?"
The answer to these questions is the same: it has to do with the momentum of the air entering or exiting the cylinder. Consider the first case: Exhaust valves are open, piston is moving upwards, forcing the air out the exhaust valves. The air moving out the exhaust ports moves with some velocity, 'v'. Air has mass, so it cannot be stopped immediately. It takes some time to slow down and stop, even though it happens very quickly (air doesn't have much mass). When you're talking about engine events, you're working in 0.01 second intervals, so that small time it takes the air to slow down and stop is significant. SO, the intake valves are open, but the exhaust is already moving OUT of the cylinder. This moving exhaust gas creates a venturi effect, drawing intake charge into the combustion chamber, and yes, some out the exhaust valves. The piston reaches TDC and starts back down, but the air hasn't stopped moving out of the exhaust valve(s) yet (it has momentum, and takes time to stop!). It slows down and stops, and only THEN do we shut the exhaust valve(s) - in this case, @ 15*ATDC.
-Now, the piston travels down to the bottom of its stroke, drawing fresh intake charge with it. It reaches BDC and starts heading back upward, but the intake valves are still open! Why? The incoming air is still moving; still has momentum. We wait until it stops moving to shut the intake valve, in this case @ 20*ABDC.
-Consider this: the faster the engine is turning, the faster the piston is moving in its cylinder. The faster the piston moves, the faster it forces air out and in of the cylinder (exhaust and intake, respectively). The faster the air is being forced out of and into the cylinder, the more momentum is has, and thus, the longer it takes to slow down and stop.
-So, your cam designer faced a compromise: "The faster the engine spins, the longer I can keep the intake and exhaust valves open, allowing momentum to be used to its full potential. "So, they pick an engine speed when it will run the most efficiently, but everywhere else must be a compromise.
-Consider this scenario: Assume your car's engine was designed for maximum efficiency at 3500RPM, which you can tell from your dyno graph because that's where the TORQUE peak is. Ignore power for this discussion; it doesn't come into play. Therefore, the intake and exhaust valve closing events will happen at some point AFTER BDC and TDC, respectively. Now, take this engine and slow it down. A lot. to 400 RPM. Think through the 4-stroke cycle again.
-Momentum has very little effect at this speed, because the piston isn't moving very quickly, relative to 3500RPM. So, around TDC, you suck in just as much exhaust as you do intake air from TDC to 15*ATDC. Then, around BDC, you actually force air OUT of the intake from BDC to 20*ABDC. This greatly reduces your compression, since you just blew a significant part of your intake charge right back out of the cylinder! You effectively make your engine less and less efficient the slower it goes.
-At some point, then engine will move slowly enough that it's no longer making much cylinder pressure. If the cylinder pressure gets low enough, the fuel/air charge will simply burn, instead of explode, and won't do much to push the cylinder downwards. So, you essentially have a misfire. Add a few of those together, and the engine quits running.
How's that for a theory? Can anyone shed some light on whether that's correct or incorrect?
Old 05-23-2014, 01:01 PM   #2 (permalink)
It's more about stroke length and piston speed. Long stroke engines (hit and miss, ships) have extremely low crankshaft rpms yet the piston speeds are comparable to short stroke engines.
Also important is how much flywheel the engine has. The old two-cylinder John Deeres had lots of flywheel and long stroke; you could idle them slow enough to count the exhaust pulses!
Old 05-23-2014, 04:20 PM   #3 (permalink)
The Rental - '13 Hyundai i30
90 day: 37.55 mpg (US)
Autocross - '04 Ford Focus ZX3
90 day: 24.76 mpg (US)
The Wifes - '02 Ford Focus SVT
90 day: 23.54 mpg (US)
was going to say flywheel too (and other rotational inertia)
Old 05-23-2014, 07:50 PM   #4 (permalink)
Southern Squidbillie
Cam theory sounds good.
It sounds like a good technical explanation of what the engine airflow is doing, and the cam and cam timing is the main control for airflow.
Old 05-23-2014, 08:54 PM   #5 (permalink)
Maybe he is referring to the rpm referenced in most trannys or torque converters? Thats based on the design where the 2 spin at the same speed vs allow slippage. Match the rpm with the power band of the engine where torque starts to kick in.
Old 05-24-2014, 12:24 PM   #6 (permalink)
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
simple answer: an engine under no load will stall when the output(torque) it is creating from the power stroke is no longer sufficient to keep the mass of the revolving/reciprocating parts spinning during the other 3 strokes(i'm excluding 2-stroke designs here obviously). the compression stroke is the one that will eat up most of the energy the power stroke makes.
if you have enough cylinders to where at least one cylinder is on a power stroke when another is on the compression stroke, the moving parts of the engine won't accelerate and decelerate as significantly and less flywheel mass is needed. 4 cylinders is the minimum for this to occur, 5 minimum for power strokes to start overlapping each other.
a less radical cam is going to help low rpm output(at the expense of higher speed output), which would allow extending the lower engine speed limit, but going below a certain speed will become impractical and potentially damaging. i tend to setup most engines to be happy with a 600RPM idle, i can probably drop that down to 500 or even 450 for some applications, but then oil pump, alternator, power steering, A/C and water pump output suffer. some transmissions don't like being spun that slowly either and will make quite some racket.
