Old 05-24-2008, 06:59 AM   #1 (permalink)
Tire Geek
CapriRacer's Avatar
Tire Engineer here - concerned about hyperinflating tires
I've been reading about folks inflating tires over the maximum printed on the sidewall and this is one site where this has been reported. I've joined just to add technical background as to why that is a bad idea!
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
Old 05-24-2008, 09:01 AM   #2 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
Welcome ... and OK, where is this information, you kinda left us hanging ...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 05-24-2008, 09:10 AM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
welcome to ecomodder...i dont personally inflate past the max, but i know many who do...what technical issues do you speak of?
Old 05-24-2008, 09:19 AM   #4 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
Great. Welcome to the site it will be good to have some expertise on the matter. What's your background and reported by who?
"Judge a person by their questions rather than their answers."
Old 05-24-2008, 09:19 AM   #5 (permalink)
Welcome to the site. As the others have mentioned I'd definitly like to see some testing that you have done to prove this is a bad idea. We have many people running max sidewall pressures here without any problems, perfect tire wear, and greatly increased tire life.
Old 05-24-2008, 11:28 AM   #6 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
(from an old "Kids in the Hall" episode)...
...Ya lost me
Folks have to back up claims here. We crave data.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 05-24-2008, 12:44 PM   #7 (permalink)
Impatient Driver
chrislk1986's Avatar
98CivicHX - '98 Honda Civic HX
90 day: 40.02 mpg (US)
My tires were 11psi over inflated. They're mud tires too. I took corners fast and did hard braking to test failure. No problems, but I reduced pressure by 5psi to be on the safe side. (the tires are at least 5 yrs old too, but taken care of).
Chris
Old 05-24-2008, 02:48 PM   #8 (permalink)
Send a message via AIM to Gone4
Perhaps we should discuss how poor the gages are on the car tire pumps. They can be off by over 10 psi in my experiences.. They always warn bicyclists not to use them for that reason. Also, they heat up a lot so you increase pressure at highway speeds if you inflate cold. I would say the concern isn't going beyond the limit of the sidewall by a few psi, but in how you do it and using what equipment, If you have other data, please enlighten us.
Old 05-24-2008, 03:04 PM   #9 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Frank, I think quite a lot of threads here and on other FE forums have got to the bottom of this as far as RR is concerned. What do you believe has been left uncoverred?
The only concern I still have is related to some areas of the safety factor, as I haven't seen much data appart from annecdotal evidence.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 05-24-2008, 03:24 PM   #10 (permalink)
is awesome
http://www.officer.com/article/artic...on=19&id=27281
This shows the relationship between temperature and tire pressure. Their test indicates that for a 20 minute drive you can expect ~+4Psi.
http://www.tirerack.com/tires/tirete...e.jsp?techid=1
Disadvantages of Overinflation
An overinflated tire is stiff and unyielding and the size of its footprint in contact with the road is reduced. If a vehicle's tires are overinflated by 6 psi, they could be damaged more easily when encountering potholes or debris in the road, as well as experience irregular tread wear. Higher inflated tires cannot isolate road irregularities as well causing the vehicle to ride harsher and transmit more noise into its interior. However, higher inflation pressures reduce rolling resistance slightly and typically provide a slight improvement in steering response and cornering stability. This is why participants who use street tires in autocrosses, track events and road races run higher than normal inflation pressures.
-Notice, no mention of higher than normal wear, or blowouts.
KU School of Engineering
'72 Datsun 240z
'96 Chevy lumina
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
New tires, advise? Chris D. EcoModding Central 35 06-09-2008 09:53 AM
Article: Green push hits tire makers MetroMPG General Efficiency Discussion 0 12-16-2007 07:14 PM
