Old 12-11-2008, 01:20 AM   #1 (permalink)
americasfuture2k's Avatar
SLOLANE - '08 Chevy (Daewoo) Aveo5 SV
90 day: 30.55 mpg (US)
make car warmer faster idea
my little 08 aveo dosnt really warm for anything. good and bad. these last 2 days it has been below freezing here and my car doesnt seem to warm as much as it did when it was in the 40's and 50's. just today it was at the normal operating temp, parked it and sat in the car before work and the temp needle started dropping. ive never had a car this small with this small of an engine.
so i google make car warmer and turned up a result in a reply to the same question on a message board or something of the sorts. it was said to use some cardboard like from a beer box to block off half of your radiator. is this a good idea or no? any other ideas how to make it warmer in the car?
If you cant fix it with a hammer, then you have an electrical problem
http://www.cardomain.com/ride/3159589
shutup, im working on it
Old 12-11-2008, 02:30 AM   #2 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
good idea, search for grill brock on this forum
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 12-11-2008, 03:35 AM   #3 (permalink)
blueflame's Avatar
Its good for your engine, not bad
Old 12-11-2008, 05:50 AM   #4 (permalink)
Hi,
I have about 3/4 of my grill blocked off, and I gain in two ways: the engine warms up faster, and there is a large aerodynamic improvement; by having the blocks on the outside.
Old 12-11-2008, 08:18 AM   #5 (permalink)
There is no problem at all with blocking off the radiator. As Neil said, grill blocks (on the exterior) are superior as they help with aerodynamics. But, radiator blocks are incredibly easy and will help with warm up. Just make sure you don't block off too much, and make sure you remove it when it starts to warm up. If its blocked off too much or gets too warm up you do run the risk of overheating, so keep an eye on your coolant temperature.
Old 12-11-2008, 09:37 AM   #6 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
"and make sure you remove it when it starts to warm up."
He means remove it when the weather starts to warm up, not your car.
Old 12-11-2008, 10:06 AM   #7 (permalink)
Yes, haha. Don't stop on the side of the road every time your car warms up to take the block out!
Old 12-11-2008, 04:54 PM   #8 (permalink)
blueflame's Avatar
Or hauling a big load like a trailer or boat
Old 12-11-2008, 05:35 PM   #9 (permalink)
Johnny 5 - '81 Honda Cm400e
90 day: 42.86 mpg (US)
Da bike - '06 Honda Shadow Vlx deluxe
90 day: 59.47 mpg (US)
i really dont see an aveo hauling or towing much
Old 12-11-2008, 06:30 PM   #10 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
I retired the civic recently and in its place i have a 1.4D4D yaris. Oh boy......
Anyway, we had a bit of a freeze recently too so i blocked up the rest of my grille so i had no opening at all. This resulted in the car warming up quicker and allowing me to be toasty inside without mpg suffering. Now, it didn't start melting the dash vents or anything!! Just a little cooler than the civic used to be at the same setting. I guess it uses so little fuel that it's difficult to warm up. Being a diesel doesn't help either. I havent wired up the fan light so when it's not freezing i open up the radiator to a 4" x 4" opening, just in case.
ollie
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
Hydrogen Generator Experiment willy57 DIY / How-to 601 08-23-2016 05:53 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
LA Auto Show: Faurecia (the make all the car interiors) SVOboy EcoModding Central 0 11-21-2008 03:25 PM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 09:37 PM
