Old 04-24-2009, 12:29 AM   #11 (permalink)
Sequential
Concrete's Avatar
The Truck - '00 Chevy S10 Extended Cab
90 day: 22.47 mpg (US)
yep
Bob,
understood
that is why I said "about" 2 times
- I did not want to explain non uniform disk inertia
HypermilingNoob said "everyone talks about light weight rims"
I've heard that talk too - and low weight rims becomes an imperative
and most of the "talk" is bogus
I just wanted to inject some data
ditto on the pressure - best first mod
my truck did not really coast before I got the pressure right
and if your are coasting - inertia becomes your rechargeable friend
Concrete
Start where you are - Use what you have - Do what you can.
caps, hub, info, rims, weigh
Easy Aero Fix? (Modding a pickup?) DifferentPointofView Aerodynamics 53 04-13-2012 05:46 PM
Tires question RandomFact314 EcoModding Central 18 04-20-2009 11:30 AM
Question about EOC with an Auto... :confused: LastBoyScout Hypermiling / EcoDriver's Ed 20 08-30-2008 06:28 PM
Prius Question Matt Herring EcoModding Central 13 07-24-2008 03:07 PM
