Old 01-10-2014, 01:29 AM   #11 (permalink)
Originally Posted by pete c View Post
I seem to recall reading a few years ago that Audi was going to adapt this concept. I think it is a great idea. Build a simple, light, cheap series hybrid powered by an engine barely powerful enough to run it at cruising speeds.
I remember that one, based on the Audi A1, fitted with a 250cc single-rotor engine.
This concept is what the volt should have been. The volt uses a much larger than neccessary engine.
A smaller, lighter and more efficient engine would be really desirable for the Volt. Even if the engine works mostly as in a stationary genset, since it's not in a stationary application the power-to-weight ratio has a more important role...
