Old 04-28-2011, 04:31 PM   #1 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
How much air are you purchasing when you buy gasoline
I was filling a gas can and it dawned on me. There was a lot of air mixed with the fuel. It bubbled up and took seconds for it to settle down. I hope that the aerator is downstream of the fuel sensor.
Noah Webster, 1787
Old 04-28-2011, 05:24 PM   #2 (permalink)
...beats walking...
...only way to confirm is by volume: if gas pump shows 1.0 gallon, then a 2.0 gallon gas can had better be exactly HALF full.
Old 04-28-2011, 07:34 PM   #3 (permalink)
Location: Live in Tucson AZ, work and car now in Detroit
Protege - '97 Mazda Protege DX
90 day: 46.42 mpg (US)
I run the pump on the slow setting for the last 3-4 gallons, lets air come back out and get more consistant fills.
Old 04-29-2011, 12:02 AM   #4 (permalink)
I think his main concern was that he wasn't paying $4. a gallon and 10% of that gallon was actually air instead of gas.
Old 04-29-2011, 04:14 AM   #5 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Some air will always dissolve in fuel (or other liquids).
Actually, 10% is what I found for diesel :
FASS Information - FASS Fuel Pumps - FASS Pumps - FASS Fuel Air Separation Systems - FASS Diesel
It's also an important issue in aviation, as the amount of dissolved gasses varies with pressure and temperature.
Old 04-29-2011, 09:40 AM   #6 (permalink)
Do more with less
Yeah you guys get it. I wouldn't doubt that air is added to fuel as a way of cutting costs for producers.
Thanks for the link euro
Noah Webster, 1787
Old 04-29-2011, 10:35 AM   #7 (permalink)
...beats walking...
...I liked their wordy euphemism for "air" = entrained vapor
...of course, fuel vapor could be in there too, but at least *it* is combustable.
Old 04-29-2011, 06:47 PM   #8 (permalink)
euromodder's Avatar
It'd get out of the fuel while it's in the tank.
You can't get more air in the fuel than the atmospheric pressure and temp allows for.
They'd have to store the fuel under higher pressure, which isn't happening AFAIK.
(It'd be environmentally dangerous to do so; the pump would start cavitating as well.
It's the same as with water, which too has gasses dissolved in it.
You can see it coming out when you're cooking the water.
Old 04-29-2011, 10:07 PM   #9 (permalink)
Polymorphic Modder
SoobieOut's Avatar
2006 DaCivic Hybrid - '06 Honda Civic Hybrid
90 day: 45.16 mpg (US)
Hummm, Carbonated gas. Maybe the rich will snap it up if marketed properly. Remember Perrier, a brand of bottled mineral water made from a spring in Vergèze in the Gard département of France.
Suckers lined up and paid $2 a bottle.
Old 04-30-2011, 05:44 AM   #10 (permalink)
The PRC.
More like someone will invent something like alka-seltzer for fuel. Expect it in the Unicorn barn next week
