09-06-2019, 10:24 PM
Everything Old Is New Again
Every VW Beetle is now a candidate to be brought to the forefront of EV technology, with a VW-branded refit with e-Up! components — 60kW motor, battery pack and fast charging system.
I'll be interested in how the conversion compares in cost to an Arcimoto FUV. I may have to change my plans.
I'd have to section or channel the body to keep these proportions.
.Two wrongs don't make a right, but three lefts do.
09-06-2019, 10:30 PM
More power than the stock motor, huh? Probably a bit heavier too. It seemed to me I could just about bench press that air cooled motor it was so light (comparatively).
09-06-2019, 11:36 PM
Compare to the Lexus motor I have now, 98lb and 68hp (I believe that's 50kW). That's less than the weight of the transmission, let alone the motor. The weight is gained back in the battery pack.
I watched it again. VW has partnered with eClassics, and the controller and charger occupy the space where the inside package shelf was. It's a heavily modified chassis and lightly modified body, not a bolt-in like EVWest does.
09-09-2019, 06:56 PM
I just watched an introduction to the ID.3. It's motor looks more like a Tesla than the eUp! motor.
It has a Passat interior on a Golf wheelbase, an instrument cluster that tilts with the steering wheel, and a Pause icon on the brake pedal and a Play icon on the gas ( ).
09-19-2019, 03:46 PM
Aerokee - '97 Jeep Cherokee XJ sport 90 day: 18.22 mpg (US) Scrambler - '74 Honda CL200 Motorcycle 90 day: 55 mpg (US)
I love it
09-19-2019, 06:37 PM
It opens up a world of possibilities.
...because...
The VIN is on the floorpan, so they will have to provide a new one. This comports with the new Federal law that allows 250 retro-bodied cars to be built without the crash testing and other Fed-regs.
09-19-2019, 11:06 PM
I'm not so excited about those classic car conversions to electric. Maybe if it could still have an on-board genset it would serve right OTOH.
09-21-2019, 05:37 AM
Vin is also on the left window defrost tab, engine compartment, front beam bracket under the tank, and 2 other "secret" places in the body. Probably easier to just redo the pan tags
09-21-2019, 04:02 PM
#9 (permalink)
...left window defrost tab, engine compartment, front beam bracket under the tank, and 2 other "secret" places in the body
Since 1939? From a computer security perspective, you can't have 'secrets' you ship with every copy of the product.
09-22-2019, 11:38 AM
#10 (permalink)
They aren't necessarily secret, just commonplace thieves are unaware they exist. For example, the engine block number used to be stamped with a vin related serial #, but you never see that anymore.
I'm not as proficient with pre - 12volt VW
