Old 05-18-2010, 07:01 PM   #1 (permalink)
low&slow's Avatar
l&s' Jag - '00 Jaguar S-Type SE
90 day: 25.86 mpg (US)
l&s' Vision - '82 Yamaha Vision XZ550RJ
90 day: 59.92 mpg (US)
L&S' Greenaero Ninja 250 - '99 Kawasaki Ninja EX250F Ninja 250R
90 day: 97.24 mpg (US)
SilverAero Ninja 250 - '04 Kawasaki EX250 Ninja
90 day: 88.24 mpg (US)
Back to back 30mpg+ tankfills!
Hi, With warmer weather finally coming to Northern CA, my fuel economy has been improving from the 26-27 mpg that I saw this fall and winter. Since its warmed up I have been getting tanks of 28-29 mpg and now my last 2 fillups have been over 30 mpg. This is with my 2000 Jaguar S-Type ( 3L V6, 5 sp AT), that has an EPA rating of 16 city, 24 freeway, 19 combined. Needless to say, I'm pleased.
Old 05-18-2010, 10:34 PM   #2 (permalink)
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
good milage for a jag,, keep up the good work, how about a bellypan? it helped me out a little,
Old 05-20-2010, 11:00 AM   #3 (permalink)
low&slow's Avatar
Thanks! I have been thinking about a belly pan for some time and now need to focus on doing it. My mods so far are a complete upper grille block, partial lower intake block, R side mirror delete and front wheel deflectors. I plan on making a cardboard one first, then using that as a template for a sheet metal version. How much of an improvement did you see with your belly pan?
best wishes L&S
Old 05-20-2010, 12:22 PM   #4 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Good going, L&S. Keep it up!
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 05-23-2010, 03:32 PM   #5 (permalink)
low&slow's Avatar
Thanks Darrell! I have to thank you again for the testing we did using your Scangauge on relative values of cruise control vs engine-on neutral coasting versus DWL. I started using the so-called "hang-time" technique as much as possible and it seems to be working. I do need to start working on a bellypan.
best weishes, L&S
Old 05-27-2010, 12:01 AM   #6 (permalink)
low&slow's Avatar
LATEST TANK WAS ...... 29.6 MPG. Close but no cigar , still pretty satisfying. I need to get working on my belly pan.
Ben Nelson's Electro-Metro Build thread bennelson Fossil Fuel Free 1499 12-22-2019 07:24 PM
I build a 4x4 Gas-Electric-Hydraulic Hybrid! bennelson Hybrids 5 02-10-2010 12:53 PM
Geeting back into Biking Doofus McFancypants Alternative Transportation 11 10-23-2008 09:50 AM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 09:37 PM
going back to VX roots from D15B soch vtec Nden Introductions 14 05-19-2008 02:35 AM
