Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 12-15-2018, 02:01 AM   #1 (permalink)
Full sized hybrid.
Isaac Zackary's Avatar
Suzy - '13 Toyota Avalon Hybrid XLE
90 day: 37.18 mpg (US)
Winter biking?
I don't bike much in the winter. But I'd like to get into it. I just don't know what will help push me into getting it to work for me. Right now I'm having problems with traction mostly. The cold is also a problem.
I have a 27" road bike which is terrible in the snow. I'm divided between getting a mountain bike, a fat tire bike or a trike. Mountain bikes can be picked up for cheap (I'm pretty cheap). But I don't know if that will be enough traction. A lot of winter bicyclers here get those fat tire bikes so they don't sink so bad into the snow. On the other hand a trike may be more stable?? I've slid under cars on several occasions, although I've never actually gotten hurt. I suppose that's what really makes me not want to ride in the winter. Do they make winter tires for bicycles? Tire chains?
Also, how do you wear a helmet and a hat at the same time safely? Also I seem to get too hot sometimes and sweat and then I'm freezing cold. I'm not sure what the best strategy would be. Any suggestions?
Old 12-15-2018, 02:20 AM   #2 (permalink)
I winter bike. The skinny-tire bikes are TERRIBLE. Forget them.
Mountain bikes are so much better. It's like the difference between slicks and snow tires for cars. I haven't tried the new fatties but then if your streets are generally plowed well enough- so YOU aren't plowing through- I find regular mtn tires sufficient.
Get a cheap, preferably free beater (garage sales, alleys, craigslist, etc.). Here in the Rust Belt the road salt will make derailleurs and such look like they've been on the bottom of a lake for 100 years in one season. Cover it all with lube and don't sweat it if you have to repair or replace it more often than you are used to.
Easily openable layers. And big pockets. You start out cold but it's amazing how hot and sweaty you can get when it's below zero. First I'm unzipping my jacket's shell partially, then completely, then unzipping the liner, then stuffing the hat and gloves in the pockets, until I finally arrive at my destination completely nude.
Isaac Zackary (12-15-2018)
Old 12-15-2018, 06:26 AM   #3 (permalink)
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
For off road snow a fat bike is by far the best. But they are expensive, heavy, and slow on the road. To commute on slushy roads in the winter, a 26x2.0 tire will work pretty well and if you are serious you can buy winter tires.
https://45nrth.com/products/gravdal-26
The Following User Says Thank You to sendler For This Useful Post:
Old 12-15-2018, 08:26 AM   #4 (permalink)
while I do not ride a bicycle anymore, I did when I was a young man, & they are correct, about wide tires, however I had a different style, & built myself, I used wide 24" with coaster brakes in rear, & I tried 3. 10, & 12 speeds on it, but I got sick of brake cables stretching, so went to a coaster brake, for the front, I preferred a custom made fork, like a chopper, but probably 4" longer than original, with a wide 20" front tire. for a seat, I had a custom made banana with the rear support rails with springs to have a form of shock. for handlebars 16" ape hanger style. & a coaster brake n front wheel, behind fork, instead of in front, so I could have engine on front fork
however I used several of the different assist engines from the 60's & 70's on it. if interested I will discuss. but it got awesome mileage from100-200 mpg depending on engine I used.
no idea how many miles I rode my custom bike, but I put over 100k mile on a true moped during same time period, from age 12-18
for clothing I use layers, & I ride motorcycles all winter.
The Following User Says Thank You to old_biker For This Useful Post:
Old 12-15-2018, 08:37 AM   #5 (permalink)
photo off the net
I have one of these; got it in the 70's. It's really for a different thread as I imagine the friction drive to be nearly useless in ice and snow.
Old 12-15-2018, 09:10 AM   #6 (permalink)
photo off the net
lol, an O&R engine also known as "chicken power" they were ok, they had a knurled metal wheel which wasn't bad actually, or you could make a custom wheel & for "spikes" use a MIG welder & just do spiral rows of spot welds, the spot welds will grab great on the tire.
the aquabug? I think is correct name, used a plastic roller, like old walk behind front wheel power propelled mowers, they wore bad in middle, had to replace roller & slipped on hills on dry pavement.
I still have 1 of each of those, plus a few others, not for sale!
Old 12-15-2018, 10:32 AM   #7 (permalink)
90 day: 49.01 mpg (US)
There's electric mountain bikes.
https://www.mbr.co.uk/buyers_guide/e...n-bikes-348254
Old 12-15-2018, 11:00 AM   #8 (permalink)
sendler's Avatar
I bought 3.0 inch studded tires for my electric bike so I could keep riding through the winter and keep it at work for lunch rides and my fat bike at home for the weekends.
The Following 2 Users Say Thank You to sendler For This Useful Post:
Isaac Zackary (12-15-2018), RedDevil (12-15-2018)
Old 12-15-2018, 06:11 PM   #9 (permalink)
Sounds like a superb way to die of hypothermia in a ditchance after being hit by a car.
My suggestion is don't.
Old 12-15-2018, 08:35 PM   #10 (permalink)
Full sized hybrid.
Ya. This town has bike lanes. But they all disappear when the streets are all snow packed, which is from now until March.
