Old 01-24-2012, 05:33 AM   #1 (permalink)
MINI COOPER S OBoarDuino
This is my plan & build thread for my OBDuino32k clone going into my 2003 MINI COOPER S.
Building blocks are :-
Boarduino Boarduino (Arduino Clone) Kit (w/ATMega328) .omlout:. nice & small
LCD eBay - The UK's Online Marketplace orange on black, same as the OE instruments
bracket Attach a Boarduino to a 16x2 LCD by OSU_FYE - Thingiverse should keep everything tight & small, made
ISO interface http://cache.freescale.com/files/ana...et/MC33660.pdf ordered 5 samples, received yesterday
Casing http://www.supertronic.com/files/d5e...027d89bafd.pdf already got one, nice & small & neat
Schematic
Waiting on LCD to arrive from China..............
Old 01-24-2012, 02:34 PM   #2 (permalink)
msc
I would suggest going with an Arduino Nano rather then the Boarduino. I looked into the specs for the Boarduino and it uses a Ceramic Resonator rather then a Crystal for it's reference clock. With the ceramic resonator for timing the base accuracy is less and there will be greater fluctuations in accuracy with temperature. Since you probably already have the Boarduion you might want to look into the possibility of switching it to a 20Mhz crystal for better timing accuracy and resolution.
Mike
The Following User Says Thank You to msc For This Useful Post:
lamb.chop (01-24-2012)
Old 01-24-2012, 03:40 PM   #3 (permalink)
Yes Boarduino already built & tested, but will look into this.
By the way I do intend to change the 5v regulator to an automotive grade one to handle any voltage spikes & drops during starting.
Old 01-25-2012, 02:34 AM   #4 (permalink)
From Boarduino website :-
16.00 MHz ceramic resonator is used instead of crystal, so cycle speed may be off by +- 0.3nS (0.5%). This isn't relevant for UART timing, servo drivers, PWM, etc. but could be an issue if you need nanosecond-precision timing. Note that the Arduino software only provides millisecond-precision timing for general sketches (1 second = 1000ms. 1ms = 1,000,000 ns)
So do I need nano second accuracy for ISO communication?
Cheers
Chris
Old 01-25-2012, 04:49 PM   #5 (permalink)
arduino provides microseconds
The Following User Says Thank You to nickdigger For This Useful Post:
lamb.chop (01-25-2012)
Old 01-25-2012, 04:51 PM   #6 (permalink)
I agree, however do I need them?
Is the ISO standard that fast?
Old 02-08-2012, 05:24 AM   #7 (permalink)
Still waiting on LCD from China.
& will replace the oscillator with a crystal to keep the timing / forum happy.
Old 02-28-2012, 04:34 PM   #8 (permalink)
LCD arrived at last & have mounted the freescale OBD ISO interface IC to a DIL adaptor.
Old 08-07-2012, 08:59 AM   #9 (permalink)
Hole cut in case to fit LCD display through.
Having battery drain issues in the MINI so need to sort them out 1st before I install...............
