Old 12-29-2010, 08:00 AM   #1 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Mini-split instead of heater and A/C?
Since many cars already have A/C installed, could it be replaced by a mini-split heat pump? That way it could be used as a heater in the winter, heating the cabin before the engine warms up, and not robbing the engine of heat when it needs it most.
Also, wouldn't a heat pump be more efficient than resistance heating in an EV?
Old 12-29-2010, 08:25 AM   #2 (permalink)
Truck2 - '04 Volvo S80
90 day: 28.53 mpg (US)
Interesting .... AC compressor pulls a lot of HP and like in a home heat pump system, or an electric compressor like on the Prius. Also it would probably have to have electric strip heat (em heat) for those really cold mornings. overall saving $$ ???
Old 12-30-2010, 04:53 PM   #3 (permalink)
Yes, a heat pump can use considerably less electrical power when compared to resistance heating. The performance ratio is called COP or co-efficient of performance. Generally, in moderate temps, heat pumps have a 3.0 to 4.0 COP (3 to 4 times less power use compared to resistance heating). However, using waste heat from the ICE when it's running, is always the most efficient use.
If you remember, the air cooled Volkswagens used exhaust to heat the cabin, just like today's small aircraft.
A combo setup could be very efficient. In fact, I see no reason why the electrically driven AC on a Prius could not be simply reversed and used as a heat pump.
Old 12-30-2010, 06:49 PM   #4 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Using waste heat is most efficient indeed. However, waste heat (through the cooling system) doesn't come untill the engine is near full operating temp, which can take a while or forever depending on your engine or motor. Recent VW TDI have resistive heaters to provide instant heat. My older TDI could certainly use a heat pump, so do all electric cars. The problem is on convential engines, the cost/benefit ratio is way too small.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 12-30-2010, 07:16 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
cujet -
I remember those. If you had a leak in your exhaust pipes the exhaust would enter the cabin. Don't get me wrong, I think it's a neat solution. At least you *knew* there was a leak and that you needed to fix it.
CarloSW2
American Solar Energy Society
