12-31-2009, 12:00 PM
ZF ecomods a transmission: 8 spd auto, EOC-able, multiple input options, fewer parts
Found this Car & Driver article interesting:
It's an interesting modular approach to making one transmission case that can be customized with multiple options, including input from (A) a "regular" torque converter, (B) an electric motor (for hybrid applications) or (C) a multiple clutch pack for increased efficiency & shifting speed (better acceleration).
ZF says the 8HP is six percent more *efficient than the outgoing sixer and nearly as efficient as a dual-clutch automated manual, which ZF also produces. However, the eight-speed is roughly 20 percent cheaper and retains the smooth, torque-converter starts to which U.S. buyers have become accustomed.
And interesting for those who like to practise engine-off coasting with automatic transmissions...
Furthermore, the 8HP has a system to maintain hydraulic pressure even when the engine isn’t running and is therefore the first automatic that’s compatible with stop-start operation—good for 11 percent better fuel efficiency, says ZF.
More info at: ZF?s 8-Speed Automatic Transmission - Tech Dept. - Auto Reviews - Car and Driver
12-31-2009, 05:50 PM
With the clutch pack or electric motor: A fine idea.
With the torque converter: Overpriced trash.
Torque converters are the tool of OPEC.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
12-31-2009, 07:41 PM
Intermediate EcoDriver
Since the torque converter locks at 1200 RPM, it may not be that bad. :shrug:
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
12-31-2009, 08:08 PM
Impressive.
So the suppliers are ready with parts that are FE for the bigger vehicles......
12-31-2009, 10:32 PM
they are commited and involved
have you seen the under side of relatively newer european car ?
they are ready , they are involved , they are living it now.
Originally Posted by mcrews
Impressive.
01-02-2010, 11:02 AM
I noticed that as well. Still not ideal, but if the US market generally demands slushy transitions in their beloved automatic transmissions, at least companies are trying to accomodate that with increasing efficiency.
