Originally Posted by Piwoslaw
I don't think that snow will be a problem if the front skirts will only be partials (just enough that the tire doesn't touch when turning): They will be smaller than the rear skirts, in fact only at the front and top of the wheel well, plus heat from the engine will melt any snow that doesn't fall out. I say go for it.
That's proof that the aeromods are working! And your fuel log shows it
Front has not been much of a problem, rears are more of an issue, but some snow is packing at front too, however there is much more clearance for it.
At our winter, there is not much of melting effect by engine heat, despite of heat from exhaust, that humidity coming from exhaust tends to freeze to rear of car also, but then again I have a drill that can be used to remove skirts
