Moon Discs for Sale
I haven’t looked in to this. Is the outer lip of a steel rim ≥ the rim size, or is it < ?
Outer lip is larger. Where the tire sets on the rim when it is mounted is where it matches the diameter of the rim size.
https://lh3.googleusercontent.com/pr...rI-k6r8fNuFW3N |
https://ecomodder.com/forum/member-f...1-100-0960.jpg
I've been wondering if could take my swap-meet Moon disks, find the centers, and trim and roll the edge to fit the 12" wheels on my new old car. The 15" holes are sl*tted out. |
1 Attachment(s)
I knew before I even clicked that it was going to be pizza pans
You guys are making me miss my old Insight Ron Burgundy . . .why did I ever get rid of that car? |
Nice looking car. |
The problem with pizza pan is they're too flat. Maybe not aerodynamically, but optically. Any waviness will become obvious as soon as they are rotating. I ran baby moons (Porsche Speedster) on my Type III Notchback. I watched a technician in a tire shop offer up the hubcap and tap it in the center with a Crescent wrench. :mad: Just a little off-center so it would twinkle. |
If by "turbo intake" hood scoop you mean "twenty dollar fake" hood scoop from Amazon then yeah it's really there I had to cover the giant hole I found in the hood when the solar panel flew off in traffic right before I traded in the Insight on my first Volt:thumbup: Which I had to do because I killed the IMA by falling asleep while I was discharging it in preparation of grid charging But those moon discs were awesome! |
So a hole was cut in the hood to accommodate a solar panel? |
I checked my ShopSmith. It has a 7.5" throw. I might have to cut them down individually then gang them together to sand to the final diameter. Then roll the lip with a roller and greased up dolly. That sounds like a better idea than it probably is. :) |
