EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   The most 'normal' solar car i've seen. (https://ecomodder.com/forum/showthread.php/most-normal-solar-car-ive-seen-30796.html)
Cd 01-01-2015 05:29 PM
Other than the skinny tires, and potato chip thinness of the car, the Sunswift eVe is the most normal solar car I have seen to date.
Even the roof height of the car is not as low as the usual solar car.
The shape is quite nice as well - even if it were powered by an ICE.
Wow :thumbup:
Weight is just 700 lbs ( yes seven hundred ) and the Cd is point 16.
http://insideevs.com/wp-content/uplo...record_run.jpg
http://images.gizmag.com/hero/sunswift-eve-offical.jpg
http://www.solarracing.org/wp-conten...Sunswift_4.jpg
Sunswift
Students Build an Electric Car With Better Range Than a Tesla | WIRED
https://www.youtube.com/watch?v=1bUd-5wqncI#t=31
Here the car attempts to break the FIA speed record over a 500km course ( thats over 60 mph over 310 miles - just amazing :
https://www.youtube.com/watch?v=ihwmtRQngcc
I came across the car on this thread at the excellent site landspeedracing.com:Oldsmobile Aerotech?
It's an actual 'doorslammer' too ( looks manta ray like in this image to me ) :http://www.wired.com/wp-content/uplo...ne-660x350.jpg
Cd 01-01-2015 05:32 PM
EDIT : The thread title should have read " The most normal solar car I've seen ( Sunswift eVe ) "
Also, i just realized this should be in the Fossil Fuel Free section.
Here is that 'dynamic' image above straightened out : http://i877.photobucket.com/albums/a...record_run.jpg
Cd 01-01-2015 06:02 PM
Crosswind testing : http://www.computationalfluiddynamic...Sunswift-b.jpg
http://www.computationalfluiddynamic...a-1024x442.jpg
http://www.computationalfluiddynamic...c-1024x620.jpg
basjoos 01-01-2015 07:52 PM
From the Wired article:
"The drive was made over 120 laps on the 2.6-mile “Highway Circuit” at the Australian Automotive Research Centre in Victoria. A pair of drivers drove in three stints, swapping when the teams did tire changes to avoid fatigue."
I wonder what kind of tires were they using if they needed to be replaced two times on a 310 mile run.
spacemanspif 01-01-2015 09:37 PM
Love the looks of the car. I'd drive it in a heart beat.
Fat Charlie 01-02-2015 08:48 AM
Australian for tire change.
http://www.jamestownliquor.com/jstli...es/fosters.jpg
wickydude 01-02-2015 10:01 AM
Michelin radial X 95/80R16 . the bottom vid shows a wheel at some point. special tires for solar vehicles.
RedDevil 01-02-2015 04:18 PM
If the tires have to be changed that often at anything less than F1 cornering speeds and downforce it makes you wonder if those special tires just happen to have an engine, fuel tank and rolling thread aboard... :)
wickydude 01-03-2015 12:38 PM
I think durability has been sacrificed for light weight and Xtremely low rolling resistance.
bit more info: Michelin - Solar Tyres | World Solar Challenge 2015
aerohead 01-05-2015 05:25 PM
tire wear
One team gave me a worn out Bridgestone Ecopia solar race tire years back and they told me that 200-miles was a typical lifespan on a road circuit.
I suspect that the continuous curves of a track environment scrubbed off the rubber at an accelerated rate,
Alex Tremulis said he was losing 20-mpg at 55-mph in the Subaru XT-100 when in the curves of his test track.
