Old 02-22-2015, 11:28 PM   #1 (permalink)
Civic VX - '92 Honda Civic VX
MPGuino not timing out / backlight stays on
Hi,
I just finished assembling a MPGuino that's using version 0.86 and installed it in my Civic VX. I noticed hours later that the backlight was still on. I tried setting the timeout lower as a test, but it still never turned off.
Everything else including the contrast seems to work fine... Has anyone had this issue? Any suggestions?
Thanks!
Old 02-24-2015, 08:21 AM   #2 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Have you been assembling your MPGuino by yourself? Can you dimm the LCD with the middle button? If not there's something wrong with LED power supply.
Give some more details about your build. If you're using Arduino board or single ATmega chip? I'll give you the solution then. But first check if you can dimm your LCD.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following User Says Thank You to AndrzejM For This Useful Post:
firehawk618 (04-02-2015)
Old 02-24-2015, 09:40 AM   #3 (permalink)
I built it with an Arduino. It does cycle through brightness levels 0 - 3 (3 is most dim) when I press the middle button. However... after the brightness level text goes off the screen, it appears to re-brighten back to level 0, no matter what option I pick.
Old 02-24-2015, 03:52 PM   #4 (permalink)
AndrzejM's Avatar
I know what's the issue there... You've used PNP transistor instead of NPN transistor to take care of the LCD backlight (or the other way around NPN instead of PNP - depends on the LCD setup). Switch to similar transistor but of different type and your problem will disappear.
Good luck!
Old 02-24-2015, 04:07 PM   #5 (permalink)
Hmm, I followed the circuit here http://ecomodder.com/wiki/images/7/7..._Schematic.GIF that shows a PNP (2N3906) although I used a 2N4403 (somewhat equivalent, also PNP) as it was what I had on hand. Is there a version that uses an NPN instead? I'm using a blue w/ white letter 16x2 standard HD44780 LCD if that makes any difference.
Old 02-24-2015, 04:31 PM   #6 (permalink)
AndrzejM's Avatar
I see... But change it to this:
And it'll solve your issue.
The Following 2 Users Say Thank You to AndrzejM For This Useful Post:
firehawk618 (04-01-2015), thewanderer (02-25-2015)
Old 02-25-2015, 10:34 PM   #7 (permalink)
Ok, I swapped it out for an NPN and now brightness 0 is off and 3 is brightest. And it stays the brightness level I pick. I'll hook it back up tomorrow to double check it's working in the car, but the brightness seems to be working properly now.
Thanks for your help!!
Old 02-26-2015, 07:06 AM   #8 (permalink)
AndrzejM's Avatar
I'm glad I could be of help
Old 03-31-2015, 11:50 PM   #9 (permalink)
97 Civic HX sedan VX trans - '98 Honda Civic LX + HX + VX
90 day: 41.9 mpg (US)
So, did this fix your display never turning off?
I am having the exact same issue.
Thanks.
1998 LX with a full HX swap + VX transaxle.
Old 04-01-2015, 12:31 AM   #10 (permalink)
Thanks.
Yes; switching the transistor fixed this issue for me. Thanks again to AndrzejM for the suggestion!
Now I just have to sort out why the MPG is off
