Old 08-04-2010, 05:31 PM   #11 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
so you might wear your alternator out sooner....
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 08-04-2010, 06:04 PM   #12 (permalink)
90 day: 38.47 mpg (US)
Not likely. You are reducing the number of revolutions that parts making physical contact have to endure by 20%. The load on the alternator will be reduced since it is running a lower RPM, but it will have to run under load for a longer duration to make up for the reduced output.
Old 08-04-2010, 09:48 PM   #13 (permalink)
Could you replace your alternator with a brushless motor?
Old 08-04-2010, 10:43 PM   #14 (permalink)
I have not heard of brushless alternators for a car, but I suppose it's possible. As far as efficiency goes, I don't think a brushless design would help very much.
Old 08-04-2010, 10:51 PM   #15 (permalink)
I just have always thought one is better than none. Road trips are hell if you run a deep cycle, especially with chargers pounding and the stereo up. Of course, an aero tonneau cover with a huge solar panel would be incredibly useful, if not indispensable. Could you make an alternator attach to an auxiliary source of power, like a Sterling engine? A hybrid running on a sterling engine during the day would be fantastic.
Old 09-23-2012, 11:34 PM   #16 (permalink)
If you want to increase the MPG on the electrical system how about doubling the Voltage from 12 to 24 volts? Power is Power I x E = P. If you double the Voltage E, and keep the P Power constant, then you Half I, the Current. All the wiring can be of a thinner gauge and the weight can be reduced. We keep hearing, "Take the weight out of the Trunk." The use of Plastics because they are lighter.
Other countries use 240 Volts? Less Grid losses. Thinner wires.
24 volt batteries for the Trucks and Diesel engines.
They have gone from 6 to 12V. Why not 24? or 48?
Old 09-24-2012, 12:21 AM   #17 (permalink)
Because the industry has no motivation to change. They've been talking about 42V electrical systems for a while since luxury cars are using more and more electricity and 12V alternators are having a hard time keeping up.
Another issue is that all the switches in the car would be less durable at higher voltages due to arcing. So you'd need a 12V system anyways.
A stopgap measure could be having alternators be designed for higher voltage outputs and then have an efficient means of stepping down the voltage. Higher specific power, lower losses.
Old 09-24-2012, 06:06 AM   #18 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
78 volt systems?
Auto voltage...24 , 32 , 48?
Old 09-27-2012, 01:46 AM   #19 (permalink)
Originally Posted by greasemonkee View Post
Might buy a set of rod bearings to go with your underdrive crank pulley, especially if the factory had an isolator in the oem unit.
Since this thread was dragged back to life, I'm wondering if there is evidence to support this claim? My OEM crank pulley had a rubber isolator, but I couldn't see it really doing anything.
Are aftermarket pulleys known to be hard on rod bearings? I would think the lighter weight alone would make them more gentle on the engine and related bearings.
free OBD2 software with MPG calc whitewiz Instrumentation 11 12-10-2014 11:53 AM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 12:59 PM
SGII first observations! gone-ot Success Stories 10 04-02-2010 02:26 AM
mpguino acted up today, lost mpg during fuel cut wagonman76 OpenGauge / MPGuino FE computer 9 06-17-2009 01:25 PM
Crank pulley removal AndrewJ Off-Topic Tech 17 06-27-2008 08:40 PM
