MPGuino
Does any one know where i can purchase a fully assembled MPGuino ?
I have made some custom mpguinos where buttons are in separate small board (and buttons-in-top version) so you can flush install mpguino and put buttons somewhere else.
I have also made custom code just like I like it extra features: * added metric version (must choose before code/firmware uploading, no change possible in settings) * bargraphs (shows 2min average 5-9L/100km - dropped 0-5L to gain better resolution) * battery voltage * trip cost (in settins you enter fuel price) * tank and current trip time in hours.minutes * saving tank trip data to eeprom (dont forget it when disconnected) * some values are shown in integers (speed, rpm) * removed leading zeroes (instead "012.45" shows " 12.45") * added dragrace screen (0-100km/h time, 400m time and trap speed, calculated horsepower) * using Atmega chip sleep mode (consumes about 5milliAmps versus 20milliAmps when in sleep) here are some pictures: MPGuino - Meelis P http://www.snap.ee/static/user_thumb...0_P8020235.jpg http://www.snap.ee/static/user_thumb...0_P8020233.jpg Mpguino is built in custom etched PCB and is same size like LCD (sits behind it, electrically it is compatible with "official mpguino"). I am using atmega 328 I think it would be around 59 euros + shipping. I have some pre-built MPGuinos at home Meelis |
MPGuino
Hi... how much to purchase and send one fully assembled to Australia ?
One in metric, buttons attached and with all the read outs... |
MPGuino
How does it read fuel usage ? like, is it milli-litres per km or what ?
* normal consumption is L/100km * then there is readout for consumed fuel for current and tank trip (just Liters) * there is also Liters/hour - good for measuring idle consumption Meelis |
MPGuino
Hi Meelis ... so how do i go about getting one of your pre assembled units ?
and was it you that made that neat cardboard box to put it in ? |
making case from thin cardboard: http://www.snap.ee/static/user_thumb...0_P2140041.jpg MPGuino ready, case covered with tape: http://www.snap.ee/static/user_thumb...0_P2170046.jpg Shipping and payment details we can discuss in private message. |
You have some nice features on your code. I've been looking for a voltage meter for my car for some time now. I would be very interested how have you changed the code to get the battery voltage for MPGuino. Is there any change that you could publish some parts of the code (*.txt format):rolleyes::) I also have a atmel 328 on a arduino dualemiloluevemilouvumilou..thingy and I have done some small changes to the code for my own needs. -Disabled some display screens I don't need, just to make it simpler and easier. -Litres/hour, Litres consumed, Speed, rpm on one screen. I used the code from mluckham as a base since it had the version for kilometers and it was very well commented.:thumbup: http://ecomodder.com/forum/showthrea...tml#post202348 |
Hi,
I made topic about this battery voltage thing some time ago: http://ecomodder.com/forum/showthrea...age-15654.html You must change schematic little-bit: make voltage divider using two resistors |
This is fantastic, thanks meelis11
