MpGuino compatibilty issues
For those of you looking to build one if you have an alternator bypass switch. It will cause Guino to restart losing tank and current memory. Happened to me 3 times today, I am going to remove alternator switch. Or figure out how to fix it.
Next problem do not hook up a injector kill switch it will cause guino to lock up. Kill you ignition instead. This happened to me 4 times today before figuring out what was causing it to happen. Just a few things to watch out for. |
Would a dedicated battery for 'guino work? A big enough battery should last at least a tankful (which is the point of having continuous power).
BB, can you describe how you are going from 12 to 5 volts on your extremely handsome guino? :)
If you have any larger capacitors laying around (or can salvage one from an old power supply or something) I might suggest putting it in parallel with the 330uf with some alligator leads as a test to see if that fixes it. The smallest one that does the job should minimize the wear and tear on that diode.
The metro alternator is a one wire? Can you expand on the alternator disconnect system a bit too? Thx, Dave. |
The alternator disconnect uses a 70 amp Potter Brumfield relay to break the output to the fuse box. The main feed (and field) wire it is like a 10 or 8 gauge wire.
I will try a 470uf I have laying here, I may have a couple larger ones can't find them right now. |
Alright well I used the 470uf in parallel with the 300uf cap, fixed reset issue.
Switched to coil kill instead of injector kill, fixed lockup problem. (My 91 doesn't have a cam sensor so couldn't use your idea dcb.) Now I have another issue, I tried some eoc, p&g today and that causes a reset. I think I am still getting a voltage drop that causes this issue. I am thinking about putting my old 1 farad cap from my car stereo days under the hood and hooking up to battery feed. I figure if this is having issues with p&g what does it do to my ecu. It probably doesn't like the voltage drops/ spikes either. I figure it would be cheap insurance in my case to just help smooth the voltage to everything a little. EDIT: Well I tried the 1 farad on the main lead from battery to fuse box, no help. I am going to go for drive again and see what I can figure out. |
Please help!! Feeling lost.
Alright I am still having issues on this.
1. resets itself when EOC, but not everytime. 2. random lock up when it resets like in #1 Things I have done to correct this. 1. added a 470uf cap in parallel with the 330 2. put a 1 farad cap on main battery feed to underhood fuse box. 3. installed a 2ah 12v battery under dash that is hooked up to vehicle via a current limiting resistor and a diode. Thus eliminating voltage drop from vehicle, was trying to see if voltage is cause. The other thing I have noticed is sometimes the cpu monitor shows random %'s like 775, 547, 180, etc. I have reloaded ver. 73 a couple times to make sure it copied correctly. Checked the shield I built multiple times. I am wondering is maybe the 7805 from radio shack is acting up, running out of ideas. Could it be the vss delay being set at 3? I love having it works great when driving normal, but I hate to drive normal now. |
