Old 10-16-2009, 04:49 PM   #1 (permalink)
Strange behavior when editing parms[]
I want to delete some unused parameters in parms[] array. I edited the parmLabels[] and #define Name number also, of course. But when the code is uploaded, it doesn't work like expected: Display is very bright and its very hard to read something. Also middle button don't change anything.
I searched the code up and down, but found no error. Any hints?
.) The number of elements in the array is defined with sizeof -> should work
.) #define contrastIdx 0 etc is OK
.) Labels also changed.
.) What I forgot to do?
Edit: I can't find the delete button.. (feel free to delete)
Found it: Of course it loads the old, bigger array on startup. Disable load in setup, run into setup menue and save. Now it works fine again
