AaronMartinSole |
01-06-2013 09:55 PM |
Originally Posted by JellyBeanDriver
(Post 349336)
The original MPGuino will not show RPM. Maybe Meelis version does ?
My metro, the vehicle speed sensor is in the speedometer. Broken Metro speedometer = no VSS signal so the MPGuino wouldn't help. Don't know if the Honda VSS is different.
Oh, very good to know. The previous owner said it was the VSS. Someone said it might be the cable. No idea, I'll have to read up and troubleshoot. You don't have to answer this, I'm going to google it, but my speedometer is just completely erratic. So it's not completely flat and dead. I just bought this Civic. I mean it just whips back and forth and everywhere, and occasionally actually displays my actual speed, lol. Pretty sure the last guy put in a new speedometer too, because the mileage is inaccurate. Don't think he meant to commit odometer fraud, maybe just tried to replace the part to fix it, but it didn't work. Might be the speedometer head I read somewhere.
I guess if I can't fix it, could I install an aftermarket speedometer?
Really hoping there's a mpguino version that shows RPMs and speed in real-time. But like you said, probably depends on reading the VSS. Gotta check that. But regardless, is there an mpguino version that does that?
edit: fixed my speedometer! It was just a corroded connector! Baking soda, water, and a wire brush fixed it up!
