Old 03-24-2013, 11:38 PM   #1 (permalink)
White Moss - '93 Geo Metro XFI
MPGuino Power Off?
This might be a dumb question...
but, other than selecting brightness 0, is there a way to power off the display?
Or does it draw so little power on brightness 0 that it won't drain my Geo's battery very quickly?
Any advice or knowledge appreciated. Finally got it all hooked up and I'm excited to start testing it!
Old 03-24-2013, 11:46 PM   #2 (permalink)
iveyjh's Avatar
none - '98 Honda Civic HX
none - '00 Chevy (Geo) Metro base
none - '00 Saturn SL1 base
Very low draw, I leave mine alone for days, weeks with no battery problems.
The Following User Says Thank You to iveyjh For This Useful Post:
edisonbaggins (03-24-2013)
Old 03-24-2013, 11:51 PM   #3 (permalink)
Thanks for the reply! I figured that to be the case, but wanted to confirm, so as not to kill my battery...
Old 03-29-2013, 09:37 AM   #4 (permalink)
Its not as good as it could be, but I've had no problems.
The backlight and display is very low power, you save about 5mA when it goes into stanby (The backlight should go off after the timeout delay around 7 minutes).
In 'standby' the unit uses about 20mA, and I believe this can be improved to about 5mA by using the proper standby mode of the processor and maybe some wiring modification to allow the display to turn-off, but that needs a software update which you can implement from someones code if you're up to modifying and reprogramming.
Would be nice if someone collected all the improvements and rolled them into a new unit, eg with low power, ignition detect/voltage compensation + readout, guided calibration for delay and flow and so on.
1995 Volvo 940 SE 2.3 Turbo estate (petrol) Running MPGuino from Dec 2012
Peak flat: 42mpg
Long run average: 37.4mpg (Jan 2013)
Typical average: 24mpg
UK based, gallons are imperial unless otherwise stated
