Old 01-22-2011, 04:28 AM   #11 (permalink)
meelis11's Avatar
Green frog - '97 Audi A4 Avant 1.9TDI 81kW
Diesel
90 day: 43.1 mpg (US)
Originally Posted by hedmanbr View Post
I read the thread that says you can solve problems of the unit acting flaky by flashing the software to it. How do you connect the unit to USB?
If you have Spiffie kit, then you have USB socked in MPGuino. If you dont find USB socket, then you dont have simple way to reflash it.
If you have ATMega chip programmer or separate Arduino, then you can reflash chip by moving chip to arduino -> reflash -> move chip back to mpguino.
Note: DCB verson of mpguino probably runs at 20MHz and does not have bootloader - then only option is to use ATMega programmer.
Meelis
