Old 12-10-2011, 02:35 PM   #1 (permalink)
Black Knight - '94 Toyota Corolla
90 day: 58.53 mpg (US)
little help
ok I found everything I need but the VSS wire. Do i need to tap in to the 7A 9A or 10A. My gut says the 9A I just need someone to back that up.
Old 12-10-2011, 03:04 PM   #2 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
Well 9A looks like the conditioned signal you want, 7A looks grounded and 10A like gibberish to anything but the speedo.
Old 12-11-2011, 04:28 PM   #3 (permalink)
ok now what I pulled the injector and i am getting 12v on both sides of the plug? here are the drawings on the car
continues over to
where do i tap into the injector now?
Old 12-13-2011, 09:26 PM   #4 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
To me, it looks like pin 1 on injector1(from the ECM) is the wire you are looking for for your injector signal.
I think you'll like this VERY handy tool. I know I do.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
Old 12-14-2011, 05:12 AM   #5 (permalink)
Eco-ventor
jakobnev's Avatar
House of Tudor
Team Mazda
Plug-in Hybrids
I think you want the blue(?) wire that is fourth from the top where it crosses over from one image to the other.
Old 12-14-2011, 10:04 AM   #6 (permalink)
Yea I was thinking like you two its the (B) that heads over to the ECM. But while looking at it I noticed the (B) only goes to two injectors then to the ECM. Then the (B-R) goes from the other injectors into the OBD test port. So I was guessing that those are the ground signal wires that its looking for. Now my question is should I be able to spade my wire into the test port and then change the referance formula during calibration. Or should I just go and cut into the harness at injector 1 pin 1.
