Go Back   EcoModder Forum > AltModding > Saving@Home
Old 11-21-2014, 07:32 PM   #11 (permalink)
NeilBlanchard, One of the modulators pissed me off the other day so I deleted some stuff.
They arent the only ones who can delete.
Originally Posted by dirtydave View Post
He deleted most of his posts for some reason...
rmay635703, you just need to match the panel to a grid tie inverter. Best for a 1 to 1 ratio as the mppt technology isnt there yet.
thomason2wheels, cost about 800 bucks, stuff purchased on ebay, saves 50 bucks a month in summer. Unmeasurable in winter.
Old 11-21-2014, 11:06 PM   #12 (permalink)
wrx4me...
no worries - '91 Subaru legacy L
90 day: 31.45 mpg (US)
weevee - '08 suzuki vstrom dl650
90 day: 61.22 mpg (US)
wrx - '09 Subaru wrx sedan
90 day: 29.8 mpg (US)
Big Bright Green Pleasure Machine - '09 kawasaki ninja 250 se
Connie - '09 kawasaki concours
Cobb, sounds like pretty fast payback for that investment...very cool....would love to do it too.
Old 11-22-2014, 06:51 AM   #13 (permalink)
Yes, it is, well worth the effort and investment even if its all Chinese made panels and stuff. With the economy a lot of people are selling their solar setups, so some good deals can be had.
For grid tie setup you want panels with higher output in voltage. typically most panels are tailored to connect to a lead acid battery bank so the voltage is around 12-15 volts. Grid tie inverters have a wide range of voltages they work from and their most efficient range is a little less than its max rating. Ie a 300 watt unit works best at about 150 watts. The 1200 watt units is 4 300 watt units in parallel.
At times our meter rolls backwards as we are using the grid as a bank.
