My aero (hopefully) fiberglass foam truck camper
1 Attachment(s)
With lots of people on ecomodder building aeroshells , boattails,trailers,kammbacks etc. I thought i would try to build a truck camper and maybe incorporate in as much aero as I could since I am building from scratch anyway.
My goal is to maintain or maybe exceed the mileage I am getting with my old camper (14-16) and stay under 1000 lbs dry weight as well as include a small bathroom in the new one. I always wanted to try the fiberglass/foam thing like I have seen here on Ecomodder by 3-wheeler and others and since the camper needs to be lightweight I went for this method. Any suggestions or comments or questions are welcome but please remember that certain things in the design are fixed like cabover height and the roof height at the very back. I can still make some changes since the main panels are not glassed together yet. Things I incorporated to hopefully help aero Tried not to go past the windshield with the cabover. Keep cabover to truck roof clearance as close as possible Built in some taper when I glassed the sides. The front and back are 3 inches narrower then the middle. Not much I know but the windows still have to in and they are flat. I am planning on a 6" or 7" radius where the sides meet the roof and the front cabover. Should be doable with foam. I am wondering about what radius should I use where the sides meet the rear panel should it be less ? Going to build a hinged fairing to help with airflow at the truck rear door window area I am looking for advise on the cabover length .I really would have extended further past the windshield but not sure how much it would affect drag.. I could still change this without too much trouble. Also the roof is really just a straight line as it is now as you can see in the picture . Is anything to be gained by giving it a curve ? Hope the pictures show up This is what I hope to end up with http://ecomodder.com/forum/member-tu...-base-only.jpg http://ecomodder.com/forum/member-tu...de-profile.jpg http://ecomodder.com/forum/member-tu...lamps-duct.jpg http://ecomodder.com/forum/member-tu...e-clamping.jpg http://ecomodder.com/forum/member-tu...icture-056.jpg http://ecomodder.com/forum/member-tu...retty-good.jpg http://ecomodder.com/forum/member-tu...ate-camper.jpg |
Like your project! :thumbup:
I don't think the aero template is going to do you much good in that situation. You can keep the sides and top to rear junctions absolutely square. Then you should put a folding boattail on the back like the semi-trailers have these days. That's what I want to do to my ginormous Lance which is only good for 10 mpg on the ol' '76 Chev. :mad: |
I'd also say that if the height at the rear is fixed, that it be the max height throughout thus cutting some frontal area out... but I know it's awful nice to have some height above the cabover.
Radii on those vertical edges right behind the cab would be good too, to the extent they stick out from the cab sides. |
Which could be added later. Maybe as separate pieces for when taking camper on/off, but clean it up (smooth transitions) when installed. Folding, removable boat-tail makes real sense. . |
Looks very nice. I anticipate you going below your weight goal.
DO you fly the thrush? |
As you were building from scratch, could you not have considered making it a pop-top to reduce frontal area?
It does look a very nice shape however... I've always hankered over a small tear-drop shaped trailer/caravan, that we could tow easily and over-night in. Seeing your method of FG over foam has the wheels turning and thinking maybe I could build my own... http://www.365campingcaravanning.com...d_trailers.htm |
2 Attachment(s)
Attachment 10438 Attachment 10439 |
Big outside and roomy inside.
Bigger than what I would have done, but nice. Too Complex? Automobile 2 - Odds and Ends pictures by kach22i - Photobucket http://i184.photobucket.com/albums/x...o-Camper-2.jpg |
Kachi, push it on up to the original front height, see what that looks like. Give the guy some headroom in the bunk.
2 Attachment(s)
lbs per sq ft. or about 320 lbs or so (just the shell, no paint ,windows, or interior) ....and yes I fly the thrush. Its one of the first turbine models Ayres made. You fly? Quote:
I am really pumped about this method of construction .It is incredible the radius you can do. All you need is a tablesaw. Here is ordinary Home depot foam in 2" Attachment 10440 and 1" Attachment 10441 You can even make compound curves if you kerf it both ways with the tablesaw. If you are kerfing large panels like I was you should make a simple plywood throatplate splitter for the table saw. |
