Old 01-09-2014, 08:47 PM   #1 (permalink)
CRX HF - '91 Honda CRX HF
90 day: 68.45 mpg (US)
Phone input for car amplifier?
I'm thinking it can be done, but I don't really know for sure. Basically, I want to use my phone 3.5mm jack to RCA inputs on my amp. Can that be done? Will it sound normal, undistorted, etc. if the volume and gain adjusted right?
Old 01-09-2014, 09:02 PM   #2 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
There should be no problem accomplishing this. Just need a way for the remote wire to turn the amp on which can be done by a simple switch.
The only thing is it will sound worse off than a stereo for various reasons.
1) the rca output on a stereo is a stronger/clearer signal
2) 3.5mm jacks are low quality connections
3) It would leave less control over adjusting the sound to make it sound as best as possible
IMO i would buy a radio with a 3.5mm jack and usb port. The usb port would allow you to connect an iphone to charge itself and play music at a higher quality. The USB would also allow for music to be streamed from a flash drive.
"The only real mistake is the one from which we learn nothing."
- Henry Ford
Old 01-09-2014, 09:07 PM   #3 (permalink)
Cool! I really want to keep my factory radio though. Alpine has a 50w RMS x4 amp that has speaker level inputs (for the factory radio) and RCAs if you have the outputs for it. You can't use them both at once obviously, but here is what I'm wanting to do.
I know I could run my phone into the tape deck, but that sounds crappy.
Old 01-09-2014, 09:24 PM   #4 (permalink)
The Dirty330 Modder
Gealii's Avatar
i would highly suggest against a tape deck aswell. I ran a tape deck to mp3 b4 and it was unbearable.
As far as your plan as cheap as decent decks are nowadays i would still buy a new 1, but if you plan on getting the amp anyway it would be cheap enough to at least try out your plan.
i'm unsure on what speakers you are using aswell, but i would make sure they are of good quality as i've blown a lot of factory speakers with just the headunit let alone amping the speakers
- Henry Ford
Old 01-09-2014, 09:36 PM   #5 (permalink)
I have the head unit and the speakers in there now. I run my phone through the tape deck adapter. I just wondered if I could add an amp into the mix and run my phone straight through it. The amp gains would probably need to be bumped up, but I guess I would have to try it. Anybody done this before?
Old 01-11-2014, 10:01 AM   #6 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
If as an add on, just remember to wire the speakers in parallel to the head unit. Without a head unit is easiest. Its been done, I've seen it on a couple old cars, and a lot of golf carts. This is actually on my list this month. You won't be able to adjust fade/balance, but I only run 2 speakers. The volume can be adjusted directly from the phone.
Shooting for 600 miles of range at 65-70 mph out of a vx.
The Following User Says Thank You to Superfuelgero For This Useful Post:
johnss (02-08-2014)
Old 02-08-2014, 04:57 PM   #7 (permalink)
johnss's Avatar
Agree with Gealii - buy like cell phone signal booster. So my usb permit to connect an IPhone with nice quality and do not need to bother.
