Originally Posted by Angelus359
blocking the grill...
what would you recommend to do that with?
I've used tape for a trial-installation.
Others have used draught-blocking foam, fiberglass, sheet metal, or corrugated plastic (coroplast, the stuff real-estate signs are made of), even plastic film.
Done on the inside like the car manufacturers do, it's an invisible mod.
For some cars, grille covers are commercially available - mainly for winter use.
