Old 07-27-2009, 06:54 PM   #51 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
I drove my moms 2000ish grand caravan with 3.3L and 44 lbs in tires and got
31.1MPG average over about 180 miles with city driving, hills, stops, and back roads. NO MODS!! I am going to mod it soon though, maybe hit that 40 mark.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 07-27-2009, 07:06 PM   #52 (permalink)
micondie's Avatar
moby van - '03 Dodge Caravan SE
90 day: 19.74 mpg (US)
That looks great. Does the wiper cover reduce fresh air flow into the van? I have looked at the wipers on my 03 and they seem to park high on the windshield. I think I could adjust them to park lower out of the air stream and reduce the drag from them.
Old 07-27-2009, 07:28 PM   #53 (permalink)
Sequential
Concrete's Avatar
The Truck - '00 Chevy S10 Extended Cab
90 day: 22.47 mpg (US)
yep
I did that - get some bosh or other low profile wiper and they almost completely draft in behind the plastic at the top of the hood
minor tweaking of arms help too
but look out - you can get them to clip each other in motion
Concrete
Start where you are - Use what you have - Do what you can.
Old 07-28-2009, 02:49 AM   #54 (permalink)
Civic - '98 Honda Civic DX
90 day: 41.44 mpg (US)
I will have to post my dads voyager on here...it is a freakin brick.
I like the van so far, I definatly think you will get close to 40mpg.
If you want to lower it check for a replacement suspension for a wheel chair van. Many of those vans have a body drop to lower the floor, but some of them also have a lowered suspension.
I honestly wish mini vans were offered with 4cyl engines and manual transmissions.
Old 07-28-2009, 03:01 AM   #55 (permalink)
40?!?
Old 07-28-2009, 12:53 PM   #56 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
There ARE 4 cylinder 5 speed minivans. Chrysler said there "was no demand" and discontinued the models. Same with turbo vans.
They still came with 4 cylinders up till recently, I think. Mine's a 2.4, which is directly replaceable with a 2.0 or even some 1.8, if you can find one (export only).
Old 07-28-2009, 02:30 PM   #57 (permalink)
Well 40 doesn't come easy in my little car that has I'd guess 1/3 less frontal area and 1000 lbs less weight. Good luck with that.
Old 07-28-2009, 04:45 PM   #58 (permalink)
97 Van - '97 Chrysler Town & Country Lxi
90 day: 21.65 mpg (US)
I have done some rough calculations on possible gains from the current baseline for my van and my realistic goal is 27mpg.... though I would really like to see 30. However, that is also with the 3.8L so I'm sure that the 4 cylinders can do a bit better than that.
Old 07-28-2009, 11:14 PM   #59 (permalink)
This wasn't directed at me was it? I was answering the comment about vans not coming as 4cyl/5speed models. Hell, I don't even think they come with anything less than a V6 anymore.
Old 07-29-2009, 12:10 AM   #60 (permalink)
No- should have edited my prior post instead.
Newb - better MPGs out of a Dodge Neon? stevewww EcoModding Central 7 10-21-2011 08:50 AM
2008 Dodge Dakota AeroCap electricman Aerodynamics 52 10-08-2011 10:47 AM
'98 Dodge Caravan 3.0L - 26 mpg pulling a trailer & 24 mpg pulling another car :) MetroMPG General Efficiency Discussion 7 05-25-2009 12:27 PM
Dodge ZEO BEV sports car cfg83 General Efficiency Discussion 0 01-16-2008 10:55 PM
electric caravan 300 mile range oldschool Fossil Fuel Free 0 01-08-2008 06:29 PM
