Old 11-01-2009, 12:06 PM   #1 (permalink)
Help need with wheel well gap filler
I'm considering using rubber from semi-truck mud flaps. Questions: 1) how to cut so that it looks nice? 2) how to permanent fasten to the vehicle - pop rivets or? Again, looks are important but so is durability. 3) If I don't use this material the other option is brush material which has been discussed elsewhere on ecomodder. Thanks much!
Old 11-01-2009, 05:28 PM   #2 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
I've never worked with mudflap material, but I would imagine a utility knife with a fresh blade in it would do the job. You might have to score it several times to get through it. Use a metal yardstick as a straight edge to make a straight cut. For a curve, go slow and don't try to cut all the way through on the first pass. Don't forget to post pictures!
-Terry
Old 11-01-2009, 05:33 PM   #3 (permalink)
Thanks much!
Old 11-02-2009, 11:21 AM   #4 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
^^^ works best for cutting curves easily
I've used a fresh utility knife to cut curves in rubber (even thick rubber) and it's no where as easy as doing it with a rotary cutter!
The Following User Says Thank You to TomO For This Useful Post:
mcrews (11-06-2009)
Old 11-02-2009, 07:11 PM   #5 (permalink)
Wow - this looks great - thanks. Buddy
Old 11-05-2009, 03:09 AM   #6 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
You might look at some neoprene rubber (diving suit stuff) as an alternative...
Old 11-05-2009, 07:04 AM   #7 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Where can you buy rubber by the sheet?
Old 11-05-2009, 07:45 AM   #8 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
you may want to look at stores that sell flooring material, they might have some undersized leftovers of rubber, vinyl or linoleum flooring on discount (especially if they also install the flooring), the material might come with an unatractive patter, but a can of spray paint will render it black. the uglyer the print the cheaper it will be.
i've used linoleum for several small experiments and it takes and keeps paint very well, it's not very stiff, but it stands up quite well, afterall it's flooring so you'd expect it to be able to take some abbuse. friction like direct contact from a tire will grind it away, buy i've actually used it in close proximity with the radiator and that didn't do much.
i've tested a piece with a lighter, it would burn a hole trough it, but the stuff itself didn't really burst into flames or anything wich makes it relatively safe for use on car imho
it came to about 11€ for several sqare meters wich was quite cheap compared to anything else
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 11-05-2009, 10:57 AM   #9 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
You can try online or eBay...a search in yer area might yield a better result.
Old 11-05-2009, 09:12 PM   #10 (permalink)
The neoprene sounds interesting, but 1) me thinks it might be pricey, and 2) it might have more "give" than I need for the purpose. But all ideas are most welcome. Thanks! Buddy
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
Front Wheel Skirts; 1950 Nash Ambassador Rokeby Aerodynamics 18 04-06-2014 12:14 PM
Help with my aero mods: 1.8L 05 Auto Toyota Corolla blackjackel Aerodynamics 73 11-22-2011 09:55 PM
2000 Mazda Protege Rear Wheel skirts Walk Through Blue Bomber Man Aerodynamics 13 08-29-2009 02:12 AM
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 04:50 AM
