Old 10-19-2009, 03:09 AM   #21 (permalink)
...and a nut below the knuckle's mounting surface.
After all that, the bearing is still closer to the mounting surface than with a traditional tie-rod end.
You mean the bolt head below the knuckle's mounting surface?
I can't see where changing the distance from ball to knuckle surface is advantageous; when the stud or bolt is stout enough to do it all without flex- and I'd sure think they are.
Old 10-19-2009, 11:50 AM   #22 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Well, yeah, bolt head or nut, depending on what you used. It could just as well have the bolt head on top of the ball.
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7381 08-02-2023 10:55 PM
Power Steering delete for fuel economy gain - anyone done it? bennelson EcoModding Central 92 01-27-2017 03:58 PM
Converting power steering to electric power steering Daox EcoModding Central 54 01-17-2017 06:16 PM
Electro-hydraulic power steering question Eddles EcoModding Central 12 09-07-2009 04:47 AM
Toyota Echo power steering delete mod? zman EcoModding Central 29 05-17-2009 08:36 PM
